Old 08-17-2008, 02:42 PM   #1 (permalink)
5.9 guy's Avatar
dodge starts hard
buddy has a 99 ctd it has to crank for about 8 to 10 seconds before it starts, if you bump the key the lift pump (on the side of the block) will run for about 25 to 30 seconds we changed the filter it was somewhat dirty. is there a pump in the tank or any other things to look at. thanks for any info.
02 2500 extended cab edge comp/drag box, K&N intake, 4 in MBRP exhaust, built trans, billet converter,HTS valvebody, autometer guages (trans temp, boost, egt, fuel press) bd frame mount lift pump, silencer ring moved out , lock-up switch
5.9 guy is offline   Reply With Quote
Old 08-17-2008, 04:22 PM   #2 (permalink)
Steveo24's Avatar
Is it doing this after it sits all night, sits for one hour????
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
Steveo24 is offline   Reply With Quote
Old 08-17-2008, 05:53 PM   #3 (permalink)
ryans01's Avatar
possible VP problems....not gonna say it yet though....
Ryan
2001 4 X 4, 3500, 2nd NV4500, II SO VP, NEW VALAIR CERAMIC CLUTCH AND HD HYDRAULICS, TSTPM3, Edge EZ, AFE, FASS 95, free 5" straight pipe minus down pipe, gauges
399/1116 2/2/08 before EZ IF IT CAN BREAK, CHANCES ARE I WILL BREAK IT
ryans01 is offline   Reply With Quote
Old 08-17-2008, 06:27 PM   #4 (permalink)
felk762's Avatar
Is it harder to start when its a hot day?
2000 2500 white quad cab short bed. 5.5" lift on 37x13.5 Toyo M/T's. FASS 150. Suncoast auto. Edge comp box. Scheid HRVP44. 150 sticks. Bell USB. ARP studs. 4" mbrp straight pipe. AFE stage 1 . Lock Up Switch. CFM IM.
felk762 is offline   Reply With Quote
Old 08-17-2008, 06:44 PM   #5 (permalink)
ryans01's Avatar
does it matter if the truck is parked uphill, downhill, or level?
Ryan
Old 08-18-2008, 11:01 AM   #6 (permalink)
5.9 guy's Avatar
i think just after it sits all night as far as i know but i will find out for sure.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
