Old 08-14-2008, 12:03 PM   #1 (permalink)
'99 wont start and surging
Can anyone shoot me some info. Searched tons of other forums and no straight answers. Truck will crank but not start. I leave the key on for a few sec and tap the gas peddle, starts!? Also surges time to time at about 2 grand. Almost feels like it is going to die out. First time cummins owner.
jeep1180 is offline   Reply With Quote
Old 08-14-2008, 12:09 PM   #2 (permalink)
Dad
Administrator
Dad's Avatar
Try this. Turn the key on and bump the starter and leave the key on. You should hear the lift pump run for about 30 seconds. Once it shuts off, try to start the truck. You could be losing prime or your injection pump has entered into the "hard to start" phase of failing. Do you have a fuel pressure guage? I'd get that checked ASAP. If you don't have fuel pressure, you soon won't have an injection pump.
Surging at 2,000 could be the APPS. It will normally leave a code.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
Old 08-14-2008, 12:43 PM   #3 (permalink)
Steveo24's Avatar
Check the fuel pressure right away!!!!
98.5 3500 2WD dually 4:10's lAuto Meter fuel, boost, pyro, and trans temp lOne piece headlights+ LED's l5 inch mitre stacks lHX 40 l150 horse Coaltrain sticks l.093 tubes l Smarty lEdge Comp HOT lStage 2 snow kit lBHAF lBD pusher pump lAmsoil, engine+diff
Steveo24 is offline   Reply With Quote
Old 08-17-2008, 03:30 PM   #4 (permalink)
2001 same problem
My 2001 is doing the same thing. I tried to reset the apps and it wouldnt start after that. It will turn over and thats it. I replaced the fuel filter and tried to bleed the injectors but nothin came out of injector 1 when I opened it. Have you found out what was wrong with urs yet? Griz
grizzlydirtdog is offline   Reply With Quote
Old 08-18-2008, 08:30 AM   #5 (permalink)
BareBackJack's Avatar
I would try to crack the line on the injection pump itself, right from the fuel filter. Bump the starter, that will run the lift pump, while the pump is running, hurry up to the line and just crack it to see if there's fuel there. It's a banjo fitting and use an 11/16" wrench. If the pump don't run or you don't get fuel, bad lift pump, I'm not sure if yours is on the engine block or in the tank but you should be able to hear it either way. And another thing clean the batteries. May sound silly but I've done that to a lot of these trucks and it works a lot of the time. I would do that first.
1998.5 AFE intake, 4 inch exhaust, superchips.
BareBackJack is offline   Reply With Quote
Old 08-18-2008, 08:49 AM   #6 (permalink)
Lift or vp 44, get it checked out right away. Good luck hope its not your injection pump.
Too many cars to list. Drag truck is in the plans for next winter as my project.
Cummins 429 is offline   Reply With Quote
Old 08-18-2008, 09:18 AM   #7 (permalink)
tracypouch's Avatar
sound like ip is on the way out.
tracypouch is offline   Reply With Quote
Old 08-18-2008, 11:21 AM   #8 (permalink)
Havent had time to try any of these tricks, but ran the codes and got P0336 and P0216.
Any suggestions on fixing these? Are they whats causing my issues?
Old 08-18-2008, 12:00 PM   #9 (permalink)
tracypouch's Avatar
the 216 is the ip death code---start saving now
98.5 4x2 160k quad cab, auto,new ip/lift,silver,bhaf,2 stroke juice,silencer what
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
