No turbo when cold
Hello everyone, I have a 2001 2500 quad cab with a 5 speed. I am not a tech but have some understanding of the workings of diesels. My truck will not kick in the turbo until it reaches about 155 or 160 degrees. After that it goes like a raped ape. When cold it will fall right on its face and barely run. Any suggestions?
#3 (permalink) |
Where are you located? I'm an idiot, but is it possible your oil is gelling?
'05HO3500qc/sb4xauto4.10icebox/EAAU4091filter/toob/ silencer:MIA 5"pipe w/dynaflex+6"tip edgejuiceattitude+gauges/striker2: Now go put on the helmet. |
#4 (permalink) |
I don't know about the 01's, but i know one of the reprograms i had done to mine had a "turbo-saver" feature that was kicked on. It does exactly that now, the turbo is silent until it reaches whatever the parameter is and then once it's there, i got my air whistle back. So it's probably normal, gotta let them warm up or they are rolling doorstops. Go easy on it when it's warming up, you don't want to wash the cylinders.
'06 Inferno Red 2500 QC, Auto, 285 70 17 BFG AT KO's, Century Ultra Topper, CoolPipe, Icebox w/4091, Amsoil's in da pumpkins and xfer case.
#5 (permalink) |
Administrator
Boost follows fuel, so your lack of boost when cold means the it's not fueling. Did this behavior just start, or has it always been that way? Checked for codes?
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's |
#7 (permalink) |
The fact that it smokes indicates it's getting the fuel. I would consider doing a "motor flush" it cleans all the oil systems. I am making a guess that the truck has been shut down too many times with the turbo hot, and the heat has burned up enough oil in the bearing to have the "coke" binding up the bearing. A motor flush will clean all the deposits out of the pressurized oil system, and perhaps make your turbo function. If not, I would guess the bearing is smoked from shutting down with the turbo spooled, causing wear from spinning on a dry bearing. A simple way to see if the turbo is sticking, is to pull the air cleaner boot to the turbo inlet off, and see if it spins freely when cold. If you do a motor flush make SURE to follow the instructions. The stuff thins the oil, and can scatter your bottom end if you load the engine up with it in the oil. Fantastic product, though. I have seen it bring compression up substantially by cleaning out carbon deposits from the ring grooves, and oil pressure come up notably. Good stuff to run through before an engine overhaul, too. Saves a LOT of parts cleaning effort.
01 3500 24v big shaft nv5600 241HD 60/80 lsd. six 35's stage 3 jammers, 4" SS behind BD brake & pulse K&N Dual carters on relays, Homebrew steering stuck to tapped box, 1.5" ram, BD box stabilizer Ugly, black and thrashed. |
