Old 07-24-2008, 04:37 PM   #13 (permalink)
rkscout's Avatar
Thats what I thought at first. Adjusted it, didn't fix the problem. Bought a new one, adjusted it, still the same problem.
rkscout is offline   Reply With Quote
Old 07-24-2008, 05:01 PM   #14 (permalink)
rkscout's Avatar
Checked the grounds. All seem to be hooked up. The only engine ground I found was the one coming off the drivers side battery. Are there more than one battery to engine grounds? Battery to body, battery to frame look good.
Old 07-24-2008, 06:24 PM   #15 (permalink)
Meierznutz's Avatar
Should be an engine to body ground somewhere, no? I would think APPS sensor too. How much fuel in tank when this happens? Could it be fuel slosh away from the pickup letting air into the line?? I would see if you can find the original fuel pick up and reinstall the Raptor. I have heard funny things from Draw Straws and the in tank pump. Change the gaskets on the lines at the fuel filter as someone may have reused an old one when they changed the fuel lines from the original pump???? Best of luck... Chris
'02 2500 QC SB 6 Sp, Con-OFE, Banks Brake and Monster Exhaust, JL Stealth Sub, AM Lunar gauges, Air Dog Raptor, Home built Hybrid 35/40 pushing 33psi!
Is there a Mega Cab in my future??? P.S. This truck for sale.
Meierznutz is offline   Reply With Quote
Old 07-25-2008, 06:06 AM   #16 (permalink)
rkscout's Avatar
It will do it no matter what the fuel level is. The problem seemed to multiple when I hooked the edge back up.
Old 07-28-2008, 02:30 PM   #17 (permalink)
rkscout's Avatar
OK. So I changed out the injector pump for a remaned one straight from cummins. Also install a new cam sensor while I had the pump out. It helped but it will still die if I am in 4th or 3rd @2500rpm hit the exhaust brake let the truck slow down to around 1000 rpms push the clutch in then it will just die. It will fire right back up. If I tap the throttle before I push the clutch in it won't die. Any suggestions?
Old 07-31-2008, 10:26 AM   #18 (permalink)
rkscout's Avatar
So after some searching it seems the problem might be vapor lock. Any fixes? What should I run the fuel pressure at. The pump I have is adjustable. Right now it's a 18psi idle. Would that help with the vapor lock?
'99 juice w/attitude, 90hp injectors, airraid, jacobs eb, sbc 13" clutch, 9000lb service truck
Old 08-29-2008, 08:31 PM   #19 (permalink)
mopawer's Avatar
I am having the same issue, I am in the process of reseting my APP, TPS. I will chime in with the results. Have you found the problem yet?
Jammer 100 HP/BD turbo Supper “B”/ S&W CAI/ Adrenaline w-pulse/ CFM+ intake/ studs/pillar EGT, FP. boost,BD FP light/BD Aux FP/Duel Interstates/Stainless 5’ exhaust/4” down pipe/ SB confe/Coming1day:Monster VP44/FP-150/The second part of Twins/Intercooler/drugs
mopawer is offline   Reply With Quote
Old 09-04-2008, 04:55 PM   #20 (permalink)
rkscout's Avatar
It rarely does it now. If I have the a/c on max and the and it the exhaust brake it will still kill it. So no, I haven't completely fix it yet.
Old 09-05-2008, 12:33 AM   #21 (permalink)
mopawer's Avatar
Do you have any codes? I have the P0216 lamo injector pump code, damm pump has only 600 miles on it. This has to be my problem, Im calling them anyway for replacment, because I didn't even tap my wire. But replacing the pump on yours didn't work so I am probably screwed too. Does your engine backfire when acelerating kind of hard and run crappy when it doesent dead pedal? To boot mine dies when trying to decel and down shift. Any way....................absolutley lost! anyone?
Old 09-05-2008, 12:41 AM   #22 (permalink)
gododge99's Avatar
i seen you there at the shop that day, i thought they got it done?
99 extendedcab longbed,edge comp nv4500,banks big brake,banks impellar,banks bighead wastegate,bd manifold smoke switch,8 inch stack, airdog 150 thanks to wally/ftediesel www.myspace.com/smokindiesel99
gododge99 is offline   Reply With Quote
Old 09-05-2008, 02:01 AM   #23 (permalink)
AaronDarbee's Avatar
I have an 04 and I was getting fuel captivation when I deleted my stock fuel filter off the side of the truck. The first thing I did was put a regulator with a return line to the tank right before the injection pump. This almost fixed the problem, but it still would happen once and a while. Then I lowered the fuel pressure to about 8psi, it totally took care of the problem, but at WOT the pressure was too low. So I ran a boost line to the regulator. That works sweet. 8psi at idle, whatever boost i am making at WOT! Just something you could try.
04.5 Cummins Puller. TST/Smarty tnt-r. A5K studded and strapped & intercooled. Stage II cp3 with custom transfer. Fully manual auto, billet front to rear.
Thanks to Darbee Racing in Liberty, KY (606)706-0942 for the transmission work
AaronDarbee is offline   Reply With Quote
Old 09-05-2008, 10:02 AM   #24 (permalink)
rkscout's Avatar
They never fixed it right. The truck was down for almost two months. I still am running the stock fuel filter. I'll try lowering my fuel pressure and see what happens. Does not throw any codes.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
