Triple Nickel Programing issues
I have been fighting some chip and or programing issues on my 03 cummins for the last 3 months and i cant get anywhere. It's the HO w/ 6 speed. I'm still running the stock cp3, injectors, and turbo. I have added the airraid intake w/ vol. tube, no silencer ring in the turbo, 4" exhaust no muffler, fass 150/150. I've been running the edge w/ attitude and i've been trying to stack it with a smarty. When i first stacked the two together i could get the timing out of the injectors and it would allow me to basically 'drain' my fuel rail. But now i can no longer get the timing and in turn i cant pull the rail below 19000. I have tried diff. smarty settings and switched to the new revoTNT tunes but my truck still will not allow me to gain the timing. I even took the edge clear off an still nothing. I'm sure other triple nickel owners have run into this but i just cant find the info or a solution. If you have any questions about the power settings or the rest of the setup ask. Any help is appreciated. Thanks
#2 (permalink) |
Super Administrator
What settings are you running on the Smarty?
![]() 03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3, F1 Flux 3.8's, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GR 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph) |
#3 (permalink) |
Well right now i'm running the TNT and i've had it as low as #3 torq @4 timing @stock rail @3... with the edge completely off of it... Doesn't run terrible. I've been from level 5 through level 9 running torq 4. timing 2, rail 3 w/ edge hooked up and on each smarty level ran the edge on settings 0 then 2 then 4 and then finally on 6. I cant get the timing out of the smarty tho no matter what i do and the only way i can get the rail under 20000 psi is with the edge on 6. When i bought the smarty i was running stock injectors stock turbo wild torq on level 9 and i could get the timing/duration to get my rail under 17000. When stacked with the edge on six i could keep my rail right under 19000 but it ran a lot harder.... which really makes no sense, but thats how it was. After a month or so of running the smarty software i had to start backing my catcher levels down to get my timing back. I ended up clear back at level 5 to get the timing. So honestly i really dont know where to go from here... i know the truck will make more power than it is presantly but i dont know where things are going wrong to get it back up and running strong again.
