Old 07-23-2008, 07:05 AM   #1 (permalink)
Air dog 100 help
Went on a 2 hr trip each way yesterday pulling a trailer, about 8000lbs total, and noticed my fuel pressure dopping over time. i started at about 13lbs, then it sat at 11 for a bit, then 10, then this morn i started it up at it was at 7!! What could be going on? I'm going to check my filter and see if that helps. Then i guess check the lines going to my gauge. Could the pump be going bad? only been on since christmas.
jbarker-if ya see this and know what i could do, let me know. i got the pump from ya so you would know.
thanks in advance
'99 24V 4x4 auto, muffler delete, quadzilla intake, Isspor gauges Boost/Fuel/Egt., recon cab lights and "BIG RIG" side running lights, airdog100 AFASS, XZT+,boost elbow, 29lbs boost, 285/75/16 Toyo Open Country ATs.
kmett is offline   Reply With Quote
Old 07-23-2008, 07:08 AM   #2 (permalink)
PureFlow Technologies Inc
2Tone12V's Avatar
Could be many minor things. Give us a call and I will walk you through a couple things. Good start though on double checking that guage.
Anthony
PureFlow Technologies Inc.
Tech Support-High Performance Division
2Tone12V is offline   Reply With Quote
Old 07-24-2008, 08:57 AM   #3 (permalink)
called them yesterday and said they would get back to me. may call them back later on today if i get the time. still running only 7psi....
Old 07-24-2008, 05:28 PM   #4 (permalink)
Meierznutz's Avatar
If you run an electric gauge, check to see that it is grounding properly. I have mine plumbed away from the block to reduce vibrations and once in a while I would see a pressure drop. I cleaned the mount and crimped the eyebolt and it hasn't hiccupped since.... Chris
'02 2500 QC SB 6 Sp, Con-OFE, Banks Brake and Monster Exhaust, JL Stealth Sub, AM Lunar gauges, Air Dog Raptor, Home built Hybrid 35/40 pushing 33psi!
Is there a Mega Cab in my future??? P.S. This truck for sale.
Meierznutz is offline   Reply With Quote
Old 07-24-2008, 07:50 PM   #5 (permalink)
I have mechanical gauges. Didn't have time tonight but will look into tomorrow hopefully. just weird how it was fine for 6 months then just started going down. truck runs great and fuel pressure gauge in truck stays right at 7lbs and never drops. so i don't know. will see what i come up with tomorrow evening hopefully
Old 07-24-2008, 08:38 PM   #6 (permalink)
Fabricator
sounds like your sucking air or the pump is taking a crap
'01 - 2500, 47re 2wd, 53 Block 70k miles and counting.... no cracks
4" turbo-back - Intake w/ heat shield - Traction bars - AirDog 150 - Edge Juice with Attitude HOT - HX-40 limited to 36psi - Getting Close to Leveled, rear dropped 2" - 7x.010" Injectors - 285/60-18's on Black Rims w/ Machined Lip - Tailgate Spoiler - Black Projector Headlights - 7" White Miter Cut Stack
14.2 @ 100 6psi boosted lanuch(hx-40 making 35psi, pre-injectors)
Rollin Coal is offline   Reply With Quote
Old 07-24-2008, 08:56 PM   #7 (permalink)
Local Rotor Head....
ah64id's Avatar
Bad tank of fuel and you plugged a filter?
05 3500 QC LB NV5600 4X4 SRW
Pricol Boost and EGT
Amsoil everywhere, BMK-11
GDP MK-2+ w/ Cat 2 mic
Smarty Jr
ah64id is offline   Reply With Quote
Old 07-25-2008, 03:36 AM   #8 (permalink)
after prob started i took that tank down to 1/8 tank, then refilled. that was when it finally droped to 7 and stayed there. changed the filter and completely emptied water seperator and nothing changed. going to run through all conections and gauge lines tonight
Old 07-25-2008, 12:11 PM   #9 (permalink)
Meierznutz's Avatar
7 lbs is a little low, no? I wont run mine below 14-15 lbs just to keep flow up to the VP-44. Could you have a VP on its way out?? Also check the overflow valve at the VP (the fitting next to the inlet from the fuel filter). They are known to get stuck in the open position and bypass fuel back to the tank, can show up as low fuel pressure on a gauge. The valve goes in with 2 gaskets similar to the banjo bolts and is only about $30 from the dealer. You may be able to pull it/claen it/ tryit to see if that works.... Chris
Old 07-27-2008, 06:29 PM   #10 (permalink)
I know 7 isn't enough. its been really weird some times its 7, sometimes its more like 8.5-9. i really don't know what the deal is. i need to call airdog again to see what they think. worried about driving the truck to much or to hard just bc i don't want to risk anything.
By the way, changed filter after prob started to see if it would help and nothing. tighted all fittings to make sure they are good. will dig into guage lines going to isolater and then isolater to mechanical gauge.
Old 07-27-2008, 07:13 PM   #11 (permalink)
Fabricator
verify the gauge works. check the vp44 over flow.
Old 07-28-2008, 02:08 PM   #12 (permalink)
anybody know the part number of the overflow valve? Stealership in town is pretty stupid when it comes to diesels so it would be nice to just tell them the numbers. how hard is it to pull valve and what are steps?
Thanks for all help. just want to get this figured out
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
