Old 07-11-2008, 09:47 PM   #1 (permalink)
cummins96's Avatar
5th gear loss HELP..nut is tight
alright so i lost 5th gear. figured it was the nut that backed off but its not.the nut is tight. the tail shaft is off now. so heres what happens i put the truck in fifth gear and im still able to turn the output shaft by hand. obviously gears 1-4 plus R its impossible to turn the output shaft by hand. i know the 5th gear shift fork is operating properly. everything is turning properly looking from the back (where the tail housing is off) ill pull the rest of the transmission out tomorrow and have a deeper look. i thought id ask you guys to see if you had any ideas on what it could be.i would really appreciate any help cause im 18 and this is my first time tearing down deep into the transmission.
thanks
Jory
1996 dodge diesel 12v...under construction
cummins96 is offline   Reply With Quote
Old 07-11-2008, 10:08 PM   #2 (permalink)
antwan718's Avatar
thanks
Jory
Dang you got a big set, I woudln't even think of opening up my tranny those to me are just scary. Either way good luck to you. I am only 17 at the moment and unless you have someone there that has torn down a tranny I would send it into a shop to have it examined rather than done at home.
-03' 5.9L w/Edge Mileage Max, 4" TBE, GHD, Modular Intake, Boost elbow
-85" Mustang GT CFI
-70" 440+6 Challenger R/T
antwan718 is offline   Reply With Quote
Old 07-11-2008, 10:25 PM   #3 (permalink)
cummins96's Avatar
well my dad is really mechanically inclined so he will be there giving me a hand when i need it. he has been threw transmissions in his race car in and out. he is new to the diesel trannies and motors tho. but ya im trying to find some info on what it could be.
Old 07-11-2008, 10:29 PM   #4 (permalink)
Grease Monkey
Cummins5SPD's Avatar
Its probably the splines in the 5th gear hub. Take the tailshaft case off and then look at the countershaft, take the snap ring off and check out where the hub is splined to the shaft. Chances are they are gone but it is an easy fix and can be done with the tranny still in the truck.
1999 QuadCab ShortBed Sport, Farmboys VP44, Fass 150, Adrenaline, SouthBend Dual Disk, Glowshift Gauges, American Racing Wheels, 35" Toyo's
Special Thanks to Farmboy's Diesel Performance, and Keystone Diesel
Cummins5SPD is offline   Reply With Quote
Old 07-11-2008, 10:48 PM   #5 (permalink)
Tech Specialist
spline issue
Ramtech is offline   Reply With Quote
Old 07-11-2008, 11:17 PM   #6 (permalink)
cummins96's Avatar
hey thanks ill will definitely check that out tomorrow. ill let you know if thats the problem
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
