Old 07-10-2008, 05:03 PM   #1 (permalink)
silvercummins31's Avatar
Exclamation Need help with fuel tank!!!!ASAP
OK its not a dodge or cummins but i need help and can't find anything. I am replacing the fuel pump on my 1997 gmc 1500 truck i have the tank down and i need to get the sending unit and stuff off to get the pump out but don't know how. Please help
01.5 2500 6 spd. HO silver, Quad Cab Short Bed. 100k, Edge Juice w/ Attitude, amsoil 4510, 4 inch Straight pipe, silencer ring gone
silvercummins31 is offline   Reply With Quote
Old 07-10-2008, 05:10 PM   #2 (permalink)
1BadOilBurnerN-Lv's Avatar
Its easier if you pull the bed off . Undo the bed bolts slide the bed back . Undo the ground to the frame and undo the fuel lines .When you unbolt the ground the plug for the pump should be right there . go ahead and un plug it . Then youll notice it has a ring that had taps sticking up . Take a screw driver and push the tabs down . Then use the screw driver and a lil hammer and tap the ring in a counter clock wise direction . Youll see the gap in the rings and the taps on the tank line up . Then lift the ring off and the whole sending unit and pump should come right out . Its real easy to figure out once u get the bed off . Get a factory pump , Ive had to put 3 napa pumps and 2 autozone pumps in my uncles truck . Then he finally went to the dealer and problem was solved .
2000 2500 sport extended cab short box. 5 inch straight piped exhaust , silencer ring M.I.A. , B.H.A.F. 354 gears , 6 inch long arm rcd lift and 37's Superchips micromax tunner
1BadOilBurnerN-Lv is offline   Reply With Quote
Old 07-10-2008, 05:47 PM   #3 (permalink)
ok thanks i bought a airtex i think its surpose to be good. Also i also go the tank off of it
Old 07-10-2008, 05:55 PM   #4 (permalink)
Well next time u have to do it pull the bed bro way easier . Its easy , ill try and find some pic's for u
Old 07-10-2008, 06:25 PM   #5 (permalink)
i was going to but i was gonna have to break some welds from my 3 inch body lift and i just broke the lines so i gotta take the pump back and get the whole assembly. there goes another 240
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
