Old 07-09-2008, 08:27 PM   #1 (permalink)
Running light woes.....
For some reason only known to someone smarter than I am, my parking lights went out the other day. I've checked all fuses, relays, replaced the switch but I still have nothing. Headlights, signals and brake lights work fine. Oh, the parking lights will light up if i lock it with the remote. Any suggestion? Thanks for any help beforehand.
2004 3500 quad dually 370k
bone stock straight piped with 285/70-17
puckwhore is offline   Reply With Quote
Old 07-09-2008, 08:40 PM   #2 (permalink)
MuscleHead's Avatar
Change the bulb, it has two filaments.One for the parking lights and the other for turn signal. Part #3157NA at most auto stores.
07 2500 TRX4 Offroad, 6.7L Cummins, 5" Pro-Comp Lift, 37" Toyo M/Ts, 18x10 Mickey Thompson Wheels,4:10 gearing,Amp Research Electric Steps,MIA Intake Baffle,Husky Liners front and rear,Bully Dog PMT ,H&S 5" Dpf Delete,K2 EGR Delete
MuscleHead is offline   Reply With Quote
Old 07-09-2008, 08:43 PM   #3 (permalink)
Plowboydually's Avatar
Just a idea i was having some problems with my lights on my truck and threw my digging i was told that the high low switch on the steering column has something to do with the marking lights.my truck is older but one idea is better than none. good luck
1999 ext. cab dually, Handshaker, 13 inch valair clutch, MBRP Exhaust, FASS pump, Pyrometer, Edge Juice w/ attitude monitor, JVC DVD Monitor, B&W turnoverball hitch
Plowboydually is offline   Reply With Quote
Old 07-09-2008, 08:47 PM   #4 (permalink)
All the bulbs are good. I should have mentioned that all exterior lights( clearance lights, bed markers, tag lights) are dead. Only my headlights, foglights working and the brake light but its seprate wiring from the light switch.
Old 07-09-2008, 08:49 PM   #5 (permalink)
Thanks for the input! This is the best place to come to for advise.
Old 07-09-2008, 08:51 PM   #6 (permalink)
Cummins CrAzY
DevilDogDiesel's Avatar
Did you check the fuse box under the hood? mine did the same thing and there is a fuse there also.
2000 2500 ext. cab short bed, AFE cold air intake, single 6 inch stack, high tech turbo, FASS 95, Scheid injectors, Adrenaline, HP intercooler boots, fully built trans., custom trac. bars, HAISLEY MACHINE ALL THE WAY!!
DevilDogDiesel is offline   Reply With Quote
Old 07-09-2008, 08:55 PM   #7 (permalink)
Yes sir, thats the only fuse box i have....... am i missing one?
Old 07-09-2008, 09:22 PM   #8 (permalink)
MuscleHead's Avatar
Yeah that info would help
Old 07-10-2008, 04:06 AM   #9 (permalink)
Cummins CrAzY
There is the one in the cab on the side of the dash.
Old 07-10-2008, 03:32 PM   #10 (permalink)
Nope....I only have the one under the hood. I've heard the the fcm( front control module) could be going bad. Now my hvac and some of my radio lights went out and it wont read cd's.Anywho, 1.5" wheel spacers are on the way. New tires are touching at the bottom.
2004 Quad Dually 370k- bone stock, straight piped, 285/70-17's
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
