Old 07-09-2008, 07:49 PM   #1 (permalink)
Feels like jumpin' out of overdrive????
Does anyone have any advice? My '01 5.9 Cummings Auto w/ overdrive feels like it is jumping out of overdrive. This has been going on since I bought the truck with 145,000 miles but it has gotten progressively worse. Transmission rebuild had no effect. I'll be drivin' down the road and when it's in a pull it feels almost like you've put your foot on the brake pedal. It has just recently started doing it in drive, too. It's in the shop now, there are no codes showing up, and the guy says there is VERY little fluctuation in throttle control readings. He is suggesting that a new $500 throttle sensor might fix the problem. Has anyone else run into this? This is gettin' ridiculous!!!
doneright is offline   Reply With Quote
Old 07-09-2008, 07:57 PM   #2 (permalink)
GA Chapter Vice President
patracy's Avatar
Yep, common problem. Here's the TC lockup switch howto I made. This will get rid of the computer locking up the trans all together, or should I say not locking it up.
TC switch howto (with pics)
And this was brought to my attention the other day on a work around. I've not tried it yet...
https://www.atsdiesel.com/PDF/120505...%2047%20RE.pdf
I'm not sure how that might or might not affect any tapped boxes. I'll try it out soon.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, full set of gauges, FP light, Holley Blue pump, 1/2" big line kit, Draw straw, 3" glasspack, TC lockup switch, Stealth VP plate, Heated WVO setup, poor man's 'pane setup, BD TC, BD VB, Billet input, Derale pan.
Parts to come: turbo and bigger exhaust, both seriously needed now!
patracy is offline   Reply With Quote
Old 07-10-2008, 07:33 PM   #3 (permalink)
You can also try HAPPIBOX.com
It has worked well for me. I think the ats method is cheaper though.
This is a common problem and I had it bad, but since the box - no more problem.
'99 3500 QC SLT Laramie, Leather. 4x4 auto trans, Suncoast VB, TSC 89% TC, Firestorm2 inj, Edge w/Attitude, Raptor lp, Glacier F/W Separator Combo, 4" Str8t Exhaust, High Flow Intake, Ats Exh manifold, Super B turbo. Amsoil dual filters. Non 53. Original owner.
AllanP is offline   Reply With Quote
Old 07-10-2008, 07:39 PM   #4 (permalink)
wesley_87's Avatar
on mine it was the tps but it was a 93
05 quadcab 3500 srw sb 4x4 yellow, g-56, edge w/attitude+edge ez, 4 in strait pipe, silencer ring out, AEM brute force HD, fass 150/150, line-x rockers and bed, b&w ball,valair ceramic/kevlar clutch, fluidampner. 387 hp 752 tq on slipping clutch and before ez.
wesley_87 is offline   Reply With Quote
Old 07-10-2008, 07:40 PM   #5 (permalink)
patracy's Avatar
$110? The TC switch and the ATS fix are less than $10 total.
Old 07-11-2008, 08:16 AM   #6 (permalink)
Free spirit
R-N-R's Avatar
For those less willing to "adjust" their factory wiring, DTT sells a noise filter for $67.
'02 2500, 2WD, 4.10, QC LB Cap, Bilstein, Gauges
DTT, AFE, PDR Boots ARP, B1-2, MagnaFlow, GRAND ROCK, Drag Comp, Regulated Fuel Delivery, IIS HRVP, M4.5, HTT
28' 6500# Sunline TT, Hensley, Prodigy
R-N-R is offline   Reply With Quote
Old 07-11-2008, 08:48 AM   #7 (permalink)
I actually had this happen on my 98.5 cummins. Believe it or not, all I did was take some sand paper to the battery terminals and cables to get a better contact/connection. Having dirty connections here can cause a significant amount of "noise" in the electrical system. Try it out, it's free...
2008, 4x4, QC, LB, Manual Tranny, AO Flash, 315 H2's, A-pillar triple guages, AFE intake, more to come...
Bando is offline   Reply With Quote
Old 07-13-2008, 07:30 AM   #8 (permalink)
Goerend Transmissions also sells a noise filter to help with the torque converter lock unlock symptom. But like bando said check your grounds first.
jnldiesel is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
