1999 2500 Brake & ABS light stay on - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 04-04-2012, 06:08 AM Thread Starter
Help why are my brake and ABS lights staying on. They came on out of the blue plenty of brake fluid. any thoughts?
DrDetroit is offline
post #2 of 8 (permalink) Old 04-04-2012, 06:11 AM
smokindully99's Avatar
Your gonna have to hook it up to scanner and see what codes you come up with to see whats wrong.
99 3500,309K on 53 block. Yeah, its got some STUFF!
97 chevy 1500 parts runner
smokindully99 is offline
post #3 of 8 (permalink) Old 04-04-2012, 06:30 AM
Akcumminspower's Avatar
Does your speedo and blower motor work ?
'05 3500 5.9L HO,Banks Ram-Air Intake,Banks Hi-Ram Inlet,Big Head Wastegate,Bullydog GT,4" Straight pipe
Akcumminspower is offline
post #4 of 8 (permalink) Old 04-04-2012, 06:32 AM
carbon's Avatar
sorry for hijacking but what does the blower motor have to do with it? I have the same problem with abs light and my blower motor is working on and off. Sometimes I lose the entire dash.
carbon is offline
post #5 of 8 (permalink) Old 04-04-2012, 06:41 AM
Well I just spent about 10 hours tracing wires haha. My abs light air bag light was on. My speedo reverse lights and blower motor all didn't work. I thought it was a bad ground somewhere after checking all fuses several times. I took it to a local audio shop and in 5 min they found a female bus fuse was blown $9 fuse and fixed everything
post #6 of 8 (permalink) Old 04-04-2012, 06:44 AM
If your ABS Light and brake light is on. You will probably get codes 950 and 999. Basically the ABS module is not communicating with the ECM. It can be condensation in the sensor plug on the ABS manifold on the drivers side behind the fuse panel under the hood if you've pressure washed your motor recently. Or it could. Be a bad ground somewhere if all your fuses are good. There's about 3 or 4 fuses for your ABS.
post #7 of 8 (permalink) Old 04-04-2012, 06:45 AM
All of those systems I listed are on the same circuit is what I was getting at
The Following User Says Thank You to Akcumminspower For This Useful Post:
carbon (04-04-2012)
post #8 of 8 (permalink) Old 04-04-2012, 12:54 PM
carbon's Avatar
wow really, I didn't know the blower motor and abs are on the same circuit. I doubt a fuse is my prob. though bc sometimes the blower works fine, and when it doesn't all I have to do is bump it. I think the blower motor is just getting old. Or am I wrong?
carbon is offline
