P0121 Accelerator Position Sensor (APPS) Signal Voltage Too Low APPS voltage input below the minimum acceptable voltage.
Basically the APPS sensor is off the end of the scale... Try a APPS reset first...
Mopar1973Man.com -=- Michael Nelson -=- 2O8-628-3645 -=- If you need a hand with your Dodge Cummins give me a shout... AirDog 150, RV275 Injectors, Edge Comp (Tapped), Straight Pipe 3" Exhaust, BHAF, Exhaust Brake, Timbo APPS, Southbend Con OFE, ScanGauge II, DiPriocl Gauges, High idle / MPG fooler, etc.
(Posted with Ubuntu Linux 12.04)
