Need Help ASAP
i have a friend with a 2001 Dodge Ram 2500 Engine 5.9L 24V HO Tranny 6SP Manual Gears 4:11 Performance Edge Comp Box,Stage 5 Edge sticks,5" staxs,Fass Lift Pump and a brand new VP44 Industrail Injection pump. the problem is when you start pulling some power off the go pedal it starts to shake and this problem started when the lift pump went out and hge didn't realise it right away so we thought the injections pump went out so we upgraded it to a Fass and then did a the brand new VP 44 fuel pump and it's still doing it so we sent the Edge injectors back and reinstalled the OEM injectors and it wasn't as noticable as before and edge sent us all new injectors we installed and it wasn't as bad as before but it is still doing it.if i had to descibe the shaking i would call it a timing shake.hope this is enough info if not i'll try and be more specific.thanks
05 LLY 3500HD Chevy EC LB DRW,Sold 06 LBZ 2500HD GMC CC SB SRW,Sold 1987 Chevy 2500,equiped with a tweaked 350 at the moment soon to get a heart transplant.. |
#2 (permalink) |
Ontario Chapter President
Did ya make sure the keyway and the key were lined up absoloutely perfect when the new IP was installed??
Dan - Ontario Cummins Crew President Ontario Chapter GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07 My new ride .... for now - 06 JEEP LIBERTY CRD. NO MODS, its a lease... |
#3 (permalink) |
i didn't install the IP but the guy that did has done quite a bit of work on the cummins so i'll contact him and see if he made sure it was done right but the problem has been the same before and after the new IP..
#4 (permalink) |
Reason I'm askin is I did the install with a mechanic buddys help and we almost squashed the key thinkin of tightening up the IP. I called Industrial Injection when we noticed the key was kinda smashed on one side and they said just file off the rounded corner and hope for the best. It wasnt really that bad like I said we never did tighten it down all the way. I would just guess it may affect timing enough to cause a shaking you describe.
#5 (permalink) | |
![]() I'd suggest checkin the entire fuel system from the tank, filters all the way to injectors, were the originals reinstalled with new washers?
#6 (permalink) |
he has 14-17 Fuel PSI at idle and WOT in all the gears and he did all new fuel filters,a brand new Fass Lift pump and the new IP so so i'm confident that we have fuel to the engine,could the Comp box cause this.
#7 (permalink) |
I'm no specialist in comp boxes and seeing as I don't have on I'd have no idea at all. I'm sure somebodys gonna chime in and help ya's out.
#8 (permalink) |
Administrator
Couple of thoughts: - What kind of smoke are you throwing when the shake is happening? - What RPM is the shake starting? Same place every time? Or, same level of boost? - Has anything else been done? EdgeComp and Stage 5 injectors seem like a lot of fuel to not see a turbo upgrade and at least head studs.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's |
#9 (permalink) |
the shaking starts at roughly 20-30PSI and roughly 1400* and it only does it in 6TH gear.he didn't do the head studs and runnin 50-55PSI on the stock charger.
#10 (permalink) |
Administrator
Hmmm. Certainly pushing the stock charger well beyond it's efficiency map which tops at 35PSI or so and borrowing some luck running a stock head gasket at 55PSI. The "only in 6th gear" part is interesting, leads my mind away from the motor toward the drivetrain, assuming you are also hitting the same engine numbers (boost, EGT's, RPM's, etc.) in 5th gear. Any performance shops nearby where you can get it on a dyno? Could be something simple like a u-joint.
#11 (permalink) | |
like i mentioned it only does it in 6TH gear when he is accelerating so i myself am thinking it's something other then a fuel related problem so he is looking into what driveline problems it could be..thanks for all the help so far.
