Erratic Throttle, NOT Injector Pump, APPS or MAP - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 09-07-2011, 12:58 PM Thread Starter
Angry Erratic Throttle, NOT Injector Pump, APPS or MAP
After wasting $165 on an APPS and another $110 on a new MAP (both threw codes & APPS checked bad per flowchart), still having the same erratic throttle problem. Codes also showed ECM and various voltage out problems, but was told could have been triggered by bad sensors. Now I think I'm down to bad ECM or loose/shorted wire (that I can't seem to find). Don't want to throw another $500 bill into the fire with a new ECM if there's anything else I haven't thought about. Anybody have any ideas?
About a week before problem happened, I replaced (auto) trans. Drove for about 4 days then problem hit. Rechecked all connections to and around trans and couldn't find anything loose, broken, etc. Can anyone help me on how to go about tracking ALL possible wiring ground/short problems? Not sure where all of them located that are associated with the ECM.
Thanx.
Michigan Ram
Michigan Ram is offline
post #2 of 6 (permalink) Old 09-07-2011, 01:16 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
is it currently showing any codes? I'm assuming you've load check batteries and cleaned terminals on both.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 6 (permalink) Old 09-07-2011, 03:48 PM Thread Starter
Yes, now throwing multiple codes including ECM, low supply voltage, APPS and other related. No injector pump codes thank God. Codes have been cleared a number of times now and most recently after new MAP sensor was installed seemed to throw even more of them (?) and seems to throttle itself even more erratically. Both batteries replaced about two years ago (with HD Interstate) and still fine although I didn't load check them, just voltage with a Fluke DMM. Truck turns over fine and headlights are as bright as ever, I'm confident the batteries are good. Terminals are very clean and undoubtably connecting.
Any ideas on wiring connections?
Michigan Ram
post #4 of 6 (permalink) Old 09-07-2011, 08:22 PM
Start at the ECM and work your way out. Remove the connectors at the ECM and see and verify that all the pins are seated to the same depth within the connector.
It does seem odd to me that all this occurred when or soon after you swapped the trans. Have you verified that nothing in on or around that area has been pinched in the swap?
post #5 of 6 (permalink) Old 09-08-2011, 12:52 PM Thread Starter
Thanks for the advice, I'll start at the ECM. Probably easier to get at after removing the fuel filter. I'll trace to the injector pump first, supply power next, then fan out and look for grounds and other sensors. I hate electronic troubleshooting...
Yes, does seem rather coincidental that this occurred 3 days after the trans swap. I've tried to find anything we worked around, but haven't come up with any obvious connection problems. I'll be looking there again for sure, but can't think of rational for anything trans signal related that should affect the throttle like that. Sure am sick of driving the wife's car though...
Michigan Ram
post #6 of 6 (permalink) Old 09-08-2011, 12:58 PM
scubieman's Avatar
Go check check batteries, my old truck the ac did not work even started perfect. Replaced battery and ac and truck pops over fine. Just idea if you have a good battery you can high jack for testing.
scubieman is offline
