Truck barely moves in drive or reverse...then won't move at all - Dodge Cummins Diesel Forum
post #1 of 1 (permalink) Old 12-08-2009, 10:56 AM Thread Starter
Hi folks...I got in my truck this morning and backed out of the garage just like normal...it was about 30 degrees here so I sat there like normal and warmed up for about 5 minutes...then when I went to go forward it barely moved...then didn't move at all...then no reverse either...if I revved up I could move a little...I turned the truck off and then could move a little more...then stop...last night coming home from work when I was warming up I smelled something burning...but figured it wasnt my truck when I got out...then when I was driving home it kicked out of overdrive...my codes were P2127 (p2127-accelerator pedal position
sensor 2 circuit low . . . . . . . . . . . . . .9-930
p2127-pps 2 voltage too low . . . . . . . .9-1520) and P0238 (simple overboost )....If my acc. position sensor goes out will this happen?...I can rev. the motor..oh, and I have already had the tranny rebuilt...thanks!
04.5 3500 SRW 5.9L HO, K&N Intake, Straight 5" Exh, Smarty POD TNT, BD Monitor, Built Tran (3 puck TC, billet shaft, shift kit, etc) AirDog II 165, More to come!
Next = Arson III, and then Injectors
Aldogs Diesel is offline
