Old 11-08-2009, 02:20 PM   #1 (permalink)
coolant coming somewere
i cant see any leaks but when i checked the oil this morning i noticed this so i took off the airbox and some of the coolant sprayed up in there and was leaking there isnt a puddle there from last night but the coolant is all over the front axle and up by the fender i checked all the hoses and there all fine i think my water pump went out wat do yall think
05 2500 5.9l edge juice wit attitude airaid intake straight pipe and sittin on 20 inch xd addicts and 33 inch nitto terra graplers and all blacked out
tatertots is offline   Reply With Quote
Old 11-08-2009, 02:41 PM   #2 (permalink)
and also i just started it up and let it run 4 a min and no coolant coming out what would it be
Old 11-08-2009, 02:58 PM   #3 (permalink)
Are you sure its coolant? If the water pump fails you will have one heck of a leak, so I doubt its that. Let it warm up and keep and eye on it and see if you can pinpoint a leak.
Diesel Nut is offline   Reply With Quote
Old 11-08-2009, 06:54 PM   #4 (permalink)
powderman's Avatar
Does your overflow hose have a clamp on it?? Some came without and over time they will leak from under neath the hose and you can't even see where its coming from. That fixed my problem. I hope yours is that easy.
powderman is offline   Reply With Quote
Old 11-08-2009, 08:29 PM   #5 (permalink)
yes i know its coolant and yes it has a clamp on it and it looks like the coolant is coming somewhere from the passanger side front of engine and it was red and it got into the intake box somehow
Old 11-08-2009, 08:34 PM   #6 (permalink)
03 Cummins
twhetten's Avatar
yeah it sounds like it could be the water pump, it is located on the front passenger side of the engine. When mine went it soaked my engine bay and covered passenger side and windshield of my truck. If it is leaking good enough the fan will blow coolant everywhere.
Ty-2003, Red, Dually, HO, NV5600, Edge EZ, Airdog, Smarty,Jammer 90s, Full CAI, Capped Rail, water/meth, Valair 3600 DD, pacbrake, full rack-o-gauges, Dual Bull Hauler Stacks, Ranchhand Full Front Replacement, Hauler Bed 482hp/1078tq on 6/6/09 w/o jammers
October Cumminsforum ROTM Winner
twhetten is offline   Reply With Quote
Old 11-08-2009, 08:49 PM   #7 (permalink)
yea ive been drivin it today and i hvnt seen it leak anymore either i dnt no it still cools the engine 2 stays under 200 degrees i dnt no wat it could be
Old 11-08-2009, 08:49 PM   #8 (permalink)
cummin2saveyou
WATERLOO49's Avatar
water pump toast mine lost all the coolant in the engine and the fan blew it all over the enging no puddling at all
2003 5.9 6 spd quad cab SLT 3500 single rear wheel, leveled rolling on brushed H2s with 35in pro comps, HD clutch, K+N intake, 7 inch custom stack with 5 inch exhaust, BANKS High ram, SMARTY TNT, capped rail, BULLY DOG outlook monitor, billet grid heater delete, mechanical pyro, successful HE351 swap.WATERLOO FIRE FIGHTER 49
NEBRASKA CUMMINS CREW
WATERLOO49 is offline   Reply With Quote
Old 11-09-2009, 09:25 AM   #9 (permalink)
well see mine still has coolant its inbetween fulll and low on the resiovor thats y i was askin
Old 11-09-2009, 12:13 PM   #10 (permalink)
Boston's Avatar
you right, I had pump failure on my 2003 I had hell big leak, I came back from 160 miles trip got home late night and when I was parking bummm pump failed I was lucky that it happened right after I got home anyway cost me $500 to get & install new one.
Boston is offline   Reply With Quote
Old 11-09-2009, 12:23 PM   #11 (permalink)
03 Cummins
twhetten's Avatar
Sorry to tell you but you got took if it cost $500, you can get a pump from autozone for between $50 and $80 dollars with a lifetime warrenty, and it is about a 30 minute job to replace it, it a piece of cake to do.
Old 11-09-2009, 05:01 PM   #12 (permalink)
Boston's Avatar
You know you right it cost less if I buy parts from AutoZone.
But Like to buy factory parts only, and water pump is aroun $300. in cost at dodge dealer
