Need 2006 belt diagram! - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 06-26-2009, 03:11 PM Thread Starter
Can't find a diagram for 2006 ram 2500 diesel. Can anyone help?
cowboyad is offline
post #2 of 7 (permalink) Old 06-26-2009, 03:32 PM
Pursuing the Great Commission
JWH_03_Dodge's Avatar
With AC
Without A/C
Goodluck
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline
The Following 4 Users Say Thank You to JWH_03_Dodge For This Useful Post:
dbcooper (08-05-2009), laranced (03-10-2013), rgsauger (10-09-2016), rhughes (10-16-2011)
post #3 of 7 (permalink) Old 06-26-2009, 05:13 PM Thread Starter
Thanks, any pointers?
Thanks for the diagrams, that's how I'm trying to route the belt but it just won't fit. I tried rotating the tensioner arm, but still not enough slack. Can you tell me what all the numbers are for so I can be sure it's the same? (we have AC) Thanks again.
Also, on our truck there is another pulley, situated between #1 and #3 on the AC diagram above. Any ideas?
cowboyad is offline
post #4 of 7 (permalink) Old 06-26-2009, 05:27 PM
Generator Pulley (1)
Water Pump Pulley (2)
Idler Pulley (3)
Power Steering Pump Pulley (4)
Radiator Fan Pulley (5)
Crankshaft Pulley (6)
Automatic Tensioner (7)
A/C Compressor Pump Pulley (8)
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to or for correct engine belt routing. The correct belt with correct length must be used.
1. Position drive belt over all pulleys except water pump pulley.
2. Attach a 1/2 inch ratchet to tensioner.
3. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
John
The Following 2 Users Say Thank You to JWH_03_Dodge For This Useful Post:
post #5 of 7 (permalink) Old 06-27-2009, 11:16 AM
If you have an extra pulley between 1 and 3 then you probably have the Jacobs exhaust brake and that would be the vacuum pump for it. Make sure you have the correct belt. You will probably have to get it from DOdge or Cummins for your application.
2016 3500 4x4, Aisin, 19.5's
2005 2500 4x4, 48re, leveled, 35's
2003 F250 4x4, 7.3L, 35's
Diesel Nut is offline
post #6 of 7 (permalink) Old 08-05-2009, 06:30 PM
dbcooper's Avatar
Thumbs up simple how to get flippin accessory belt off!!!!!!!
Idler Pulley (3)
this needs to be added as a sticky!!!!!!!!!!!!!! please. great post thank you - been looking all day for this exact post!
04 Ram 3500 HO Laramie, Banks Sleeper, SVO burner
NEW AIR DOG FUEL PUMP!!!!!!!!!!!!!!!!
dbcooper is offline
post #7 of 7 (permalink) Old 08-05-2009, 06:40 PM
Diesel Junkie
TVtruck's Avatar
That would be my guess as well....at least that's where the vacuum pump is mounted for the Banks Brake on mine.
Tim
2010 3500 C&C 4X4 ;EBY Built Flatbed ;H&S Black Maxx; DPF/EGR Delete; S&B CAI;South Bend CAISDD3600-GK,
Ohio Coal Rollers
Cumminsforum.com
TVtruck is offline
