Old 01-29-2007, 09:29 PM   #1 (permalink)
Turbo's Avatar
'99 doesnt want to idle in gear
An employee of mine has a '99 with about 165k complete stock. His truck started dieing if he came to a stop, letting the rpms drop far enough with a load on the motor(auto trans), the truck would die. If you start it back up it will run, and idle. The moment you put it into gear the idle drops and surges. If you give it gas or drive it and let off again it dies. What should we look at that may be causing this? Maybe a fuel supply issue? He doesnt have a pressure gauge, which I suggest he get one, so we dont know what the fuel pressure is doing.
Any help is greatly appreciated.
Justin Harris
Justin Tyme Autocraft
2000 2500 SLT Laramie Quad LWB - PICS
Turbo is offline   Reply With Quote
Old 01-30-2007, 08:27 PM   #2 (permalink)
Tech Specialist
I would start by changing the fuel filter, then check the fuel pressure on the outlet side of the filter.
A bad transfer pump will do as you describe, but so will a bad injection pump, or a fuel hose that is leaking air into the fuel, crud in the in-tank pickup tube screen, or even a bad overflow valve.
The best thing is to make sure you have a clean filter, have primed the truck, and then test the fuel pressure.
It is also a good idea to dump the error codes and look for an injection pump related error.
Oregonpharmer is offline   Reply With Quote
Old 01-30-2007, 08:33 PM   #3 (permalink)
GottSoot's Avatar
yeah get a fuel pressure reading right away, so he knows if the VP is starving.
Billings Mt. Home of the Dirtymax!! 9.46 149MPH
GottSoot is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
