👋 Welcome to the Cummins Diesel Forum
2019+ 4.5 Gen Ram 6.7 Cummins
2019+ “5th” Gen
DPF Equipped 6.7s
The VP44 5.9s
The P7100 5.9s
VE pump 5.9s
NO ADVERTISING
General Forums
Specialty Forums
Forum Resources
Marketplace
Vendor Member Section
Regional Forums
Forum Support
Community Hall
Latest Posts
I have a 95 that had a bad steering box. I pulled the remanned box off of my 2001 parts truck and the drag link end is smaller than the hole in the pitman arm. Does someone manufacture a bushing for that or do I just need to change the pitman arms? Thanks in advance for any help!2 replies 97 views
Good morning everyone! I have a 1998 12 valve with a 47RE transmission. I’m looking to do a G56 swap but have been struggling to find what I need to do with the wiring to bypass the neutral safety switch to start the tuck. If possible I would like to eliminate any check engine lights and would...4 replies 204 views
I'm looking at just disconnecting the grid heater wiring in the simplest way possible. I'm not super familiar with it's wiring setup. Is there a ground for the relay I can just remove get it to stop working? Not really worried about a check engine light to be honest. I'm not looking at a full...4 replies 77 views
Any one know where to find a dust cap for an independent 2wd front hub.11 replies 176 views
