Old 01-26-2007, 09:26 AM   #13 (permalink)
DBLR's Avatar
I agree with Duluth Diesel, you need to use the red bottle of PS Diesel 911, it is used to de-gel, gelled diesel fuel. I think anyone who drives or lives where the fuel could gel should carry one or two bottles of PS Diesel 911 in the red bottle. I always keep at least one bottle in the truck all winter long. You do know that you can pour PS Diesel 911 directly in to the fuel filter housing after installing a new filter to help de-gel the fuel in the fuel rail when you go to start it?
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's
DBLR is offline   Reply With Quote
Old 01-26-2007, 12:32 PM   #14 (permalink)
butt6767's Avatar
well finally got it going. wont let that happen again, thanks to all
butt6767 is offline   Reply With Quote
Old 01-26-2007, 06:52 PM   #15 (permalink)
butt6767's Avatar
well i got towed home i guess i did'nt get it. anyway someone told me add a little kero to the tank and new fuel filter filled with kero, is that ok or will it get to hot.
Old 01-27-2007, 07:18 AM   #16 (permalink)
Twin Port Sales, Authorized Amsoil Dealer
Duluth Diesel's Avatar
Well, kerosene has no lubricity whatsoever. If you're running a VP44 truck, I'd worry a little about that and throw in the 2 stroke oil. You should fill in your signature so we know what you have for a truck!
But yes, mixing in a little kerosene will lower the gel point of the fuel.
Duluth Diesel is offline   Reply With Quote
Old 01-27-2007, 07:46 AM   #17 (permalink)
DBLR's Avatar
Like I said you can pour PS Diesel 911 in to the filter to help de-gel the fuel in the fuel line and it shouldn't hurt any thing.
Old 01-27-2007, 07:53 AM   #18 (permalink)
butt6767's Avatar
did'nt try yet today i have a p7100 pump.96
Old 01-27-2007, 08:43 AM   #19 (permalink)
2 Cycle Oil Guru
Mopar1973Man's Avatar
In either case (P-Pump or VP44)... I would very careful on the amount of anti-gel you dump in. This stuff is mostly mineral spirits or naptha. I works great as a thinner (anti-gell) but remember while your doing this your reducing the lubricity of the fuel. (Causing more wear to your IP pump). With ULSD (#2, Winter blend, #1) regardless has been reduced in sulfur (Lubricity) greatly. So use these products very carefully. Don't add wildly...
As for the 2 Cycle Oil it has worked wonderful so far with no problem yet... I'm at +10*F for a start this morning... I know it'll fire up easy...
Originally Posted by Duluth Diesel
And yes, try the 2 stroke oil. Mopar1973Man speaks the truth!
Thank you Chuck...
It might get it to start but you'll do some serious damage to your IP pump. Remember everything that yyour using (kero, PS 911, etc) uses chemical that are very similar to kero, naptha, xylene for anti-gel properties... So that why its a good choice to switch or blend a heavy dose of 2 cycle oil over the top... To proptect your expensive IP-Pumps!
Old 01-27-2007, 09:10 AM   #20 (permalink)
Administrator
MR4WLR's Avatar
If you have the connections for a garden hose...run warm water over the lines/filter canister to warm things up
Corey Ritter - Amity, OR
'04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd, HO, Edge EZ, TST PowerMAXCR, Smarty, SPS 66, Rip's 4", AFE PG7 W/torque tube, FASS 150, Superlift leveling kit, Ride Rite's w/onboard air, Line-X. Torklift camper tie downs, fuel vent mod, CB, GPSmap 168, Buckstop/Warn 12,000 lb, KC Daylighters, MTL w/prolong in trans, Haisley DD, DiPricol gauges and Quad Commander. 77K
513/1043 Fast Specialties DDD 4-15-2006 TST-EZ stack, Quickest 1/4 mile ET 13.949 @ 96 MPH @ PIR
Hauls Lance "Lite" 1025 @4klbs
Wifes truck '98 Intense Blue 12V QC LB 4X4 Auto
MR4WLR is offline   Reply With Quote
Old 01-27-2007, 10:33 AM   #21 (permalink)
butt6767's Avatar
she is running i didnt put anymore melt down in it i guess with it plugged in all night and a 200 watt light on top of the tank worked , it is also alot warmer today. thanks to all
1996 4x4 2500 laramie extendacab , 10 plate full foward ,star wheel loose, bhaf ,. 4" turbo back exhaust staight back ,One mean dog security system
Old 01-27-2007, 12:57 PM   #22 (permalink)
I said in an earlier post that plugging in the block heater would warm things up enough to unclog a gelled filter. Gotta warm up everything! Glad she's back on the road.
-Chuck
Old 01-29-2007, 10:11 PM   #23 (permalink)
Power service
Why is Power Service in the blue bottle not talked about? I bought six 32oz bottles for $3.00 each. Work at a auto parts, got them at cost.
Tisisit is offline   Reply With Quote
Old 01-30-2007, 10:57 AM   #24 (permalink)
DBLR's Avatar
I've only seen white (for winter time) and silver (summer time use) bottles. Are you sure its PSD?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
