Help!! "06 5.9 oil discharge thru breather tube - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 12-13-2006, 01:34 PM Thread Starter
My '06 is dumping lots of oil, (12 to 18 qts) between changes thru the breather tube. Initially was thought to be a leak at 92,000 miles. Called dealer and informed him as I was out of town, got back at over 100,000 warranty and dealer conveniently didn't remember the call. Chrysler says too bad, out of warranty. A local diesel shop diagnosed a bad turbo. After a week of extremely poor service and missing parts from Turbonetics, and $2000.00 in parts and labor the new turbo is installed and the problem is not changed. The local shop has diagnosed high crankcase pressure, but doesn't know why. There is no evidence of oil in the coolant or vice versa. The truck runs fine and has no power loss or smoke, just the entire underside is covered with oil and visible smoke and pressure from the breather tube.
Blue '06 Hauler is offline
post #2 of 8 (permalink) Old 12-13-2006, 01:38 PM
bway1341's Avatar
Wish i could help that is alot of miles on an 06
2008 2500, 4x4 auto, dpf gone egr capped,
bway1341 is offline
post #3 of 8 (permalink) Old 12-13-2006, 01:42 PM Thread Starter
I haul RV's thruout US and Canada, bought it new in early February, now has 127,000 on it and can't work without it, not fun around Christmas except for the additional time off at home. Thanks for the reply.
post #4 of 8 (permalink) Old 12-13-2006, 04:47 PM
Mod Maniac
RAMROD2006's Avatar
you havent puked an injector and the diesel is overfilling your crankcase and causing the blowby?
If not I hate to say the only other think it could be is a bad ring or two or burnt piston
2006 Ram 2500 Quadcab 4x4(stick) 6spd(g-56) Flame Red, Smarty stacked with Edge juice with attitude, HTT 64/14 Turbo, K&N Torque tube & Filter, 100 hp injectors. 5" exhaust, Nerf bars, Bull bumper, Isspro mechanical gauges on A-pillar. LED tailights, Fire and Ice Light bar.(616hp 1112tq)
In service 15-July-2006. SEMPER FI!!!
RAMROD2006 is offline
post #5 of 8 (permalink) Old 12-13-2006, 04:47 PM
Tech Specialist
WorkhorseDiesel's Avatar
You might want to do a search. There is a thread on here about a pressurized crankcase or something similar. I just ran across it a couple of days ago and there was someone that knew a quite a bit about what to do.
Quick check......pull out your dipstick and take a whiff of the oil in the crankcase. If it has a strong diesel odor then he's right, injector leak. I didn't even think of it but now that I remember right, someone had the same problem.
2001.5 White 2500 Reg-cab 4x4 NV4500 4.10 BHAF WALBRO GSL392 Edge Juice + Attitude VALAIR HD OFE Scangauge II 315 Cooper S/T's Optimas custom black grille & blue graphics ** Diesel Fuel Treatment is here **
WorkhorseDiesel is offline
post #6 of 8 (permalink) Old 12-13-2006, 06:43 PM Thread Starter
Latest guess by 2 performance diesel shops in the area is that the valve guides are shot??? Still waiting on a way to get a more accurate diagnoses before letting them throw in any more unneeded expensive parts. There is no fuel in the crankcase, just oil that leaves at a rapid rate thru the breather tube. No performance or smoke issues either, just oil blowby. Does valve guides make sense to any of you?
post #7 of 8 (permalink) Old 12-13-2006, 07:26 PM
Unhappy 05 Dodge Cummins Breater oil leak
I have a Dodge 2500 4x4 cummins with 15 k miles that just had an oil change and within 200 miles has blown over 2 quarts of oil out the breater tube. I am scheduled to see the dealer next Tuesday so I'll find out what might be the problem and report back.
wapiti is offline
post #8 of 8 (permalink) Old 12-13-2006, 07:44 PM
Rbratby's Avatar
you could have a vacuum leak somewhere. check all of you vacuum lines.
Modified 97 3500
Rbratby is offline
