Any way to ungel the diesel - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 12-23-2008, 02:23 PM Thread Starter
Hi all:
My first post here and I most certainly need some help!! Temperatures here have dropped to -32 below and can't get my Dodge Ram to start. Dealer said is is most likely due to diesel becomming gel and that they want 24 hours and $450.00 to "clear the problem". Is there something that we can add to the diesel to help ungel it or is there a "SAFE" way to warm the truck to get things flowing again. Have an urgent trip to make in the new 24 hours.
Thanks so much and have a most excellent day!
Dwightp
dwightp is offline
post #2 of 19 (permalink) Old 12-23-2008, 02:27 PM
lvin4jc's Avatar
Well, that's a bunch of hooey, they just want to bring it in the garage and let the warmth of the garage thaw it out. You can add a product like Power Service that will prevent gelling, but I don't know of a product you can use after the fact.
Back home in Montana they are having the same problem, the solution there is to drape some blankets down the sides of your truck and stick a heater down there, the blankets (or plywood or whatever) not only contain the heat, but they also keep the wind out, good luck :thumbsup
2001-4X4-47re-3.55 gears-Amsoil 4510-Isspro triple gauge pod- Leveling kit-Straight piped-Debadged - 240,000+ Miles and counting
lvin4jc is offline
post #3 of 19 (permalink) Old 12-23-2008, 02:35 PM
nomod_Dodge01's Avatar
Like Lvin4jc said, the dealer is going to let it sit in the shop, thaw out, and change the filters. You can try some Powerservice Diesel 911. Link is below. Once you get it running, you are going to want to change the fuel filter. And make sure you add additive to your tank everytime you fill up.
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economy
2001 Stock Dodge Ram 2500 SLT QC/SB, 4" MBRP SS, Airdog 100, 3.55 Gears, 4X4, Patriot Blue, Tinted, Dodge Snapless Tonneau Cover, 8' Fisher Plow....Future Plans gauges, tuner.
nomod_Dodge01 is offline
post #4 of 19 (permalink) Old 12-23-2008, 02:44 PM
Banned
there is 911 you can buy and put in the tank and your fuel filter witch its probly time to change the fuel filter aswell. you can also get some tarps rap your truck with them put a big heater under it and thaw it out or if you got a heated shop or a friend with one put it in there and thaw it out.
what year of truck do you have?
moparfan1234 is offline
post #5 of 19 (permalink) Old 12-23-2008, 02:44 PM
Dad
Dad's Avatar
Power Service Diesel 911 will reliquify gelled fuel. You'll need to put some in the filter canister and some in the tank.
- Mine: '09 GMC Sierra LTX ECSB 2WD - Deletes, 4" Exhaust, AEM CAI, DP LMM 2.6 Stg 1.5 Drag Turbo, BD Manifold, Diamond Eye Downpipe, All Season Diesel Performance EGR/Grid Heater delete, PPE Race Valve, Edge Insight, '08 Hummer Wheels, DSP5 - EFI Live tuning by Mark Broviak @ Danville Performance.
Dad is offline
post #6 of 19 (permalink) Old 12-23-2008, 02:51 PM
lvin4jc's Avatar
Good call, I forgot about 911, but I run powerservice year round so I haven't needed it.
lvin4jc is offline
post #7 of 19 (permalink) Old 12-23-2008, 04:07 PM
Ram3500Dually's Avatar
Methol Hydrate will degel it
2013 Ram 3500 Dually CTD 6.7/Aisin/4:10 LSD
Previous Rams:
90 CC Dually, 94 RC LB, 95 CC SB, 98 QC Dually, 00 QC Dually, 01 QC Off Road, 03 QC Dually, 05 QC Dually, 08 QC Dually, 10 CC Dually
Ram3500Dually is offline
post #8 of 19 (permalink) Old 12-23-2008, 04:14 PM
Banned
same as they said about 911 red stuff ps. but you will have to warm under truck. like maybe heater that will blow heat under truck. have tarps draped over truck. it will work
diesel pap is offline
post #9 of 19 (permalink) Old 12-23-2008, 04:38 PM
Duluth Diesel's Avatar
The above posts are correct. An anti-gel will not correct an already gelled fuel issue. this would solve the problem, and I recommend keeping a bottle in your truck at all times: AMSOIL Diesel Recovery Emergency Fuel Treatment
But $450??? They're nuts. All you really need to do is get the truck into a warm shop overnight and get some anti-gel on board. Also replace the fuel filter while you're at it since gel issues really manifest on the fuel filter face.
Also read about anti-gels here: anti-gel explained
-Chuck
Duluth Diesel is offline
post #10 of 19 (permalink) Old 12-23-2008, 05:00 PM
Interesting, a mixture of white spirits(paint thinner) and naphtha........
Previous Rams:
post #11 of 19 (permalink) Old 12-23-2008, 05:32 PM
PA Diesel Fuel Mafia-Don
Whippit96's Avatar
-Chuck
So what if there is only liquid fuel in the filters...mine is gel'd up post airdog. Only thing I can do is wait for it to get warmer as I have no garage or torpedo heater.
1999 2500 Quad Cab 4x4, Edge Juice w/Attitude, AirDog 100,II 62mm snail ,6" stack, BHAF, 125hp Injectors,5spd swap w/ Valair 3850 DD, thanks to Holland Court Diesel, and TheDityD!
Whippit96 is offline
post #12 of 19 (permalink) Old 12-23-2008, 06:08 PM
ben762's Avatar
Location: Eureka, CA originally - Grand Forks, ND for now
I just changed out my fuel filter (it had 6k miles on it) and put some 911 in there + some in the tank and the truck started right up. I too had my first encounter with gelling last week and the advice I got here got me rolling again.
2001, NV4500, 4x4, 3.55, Quad Cab/Short Bed (FS 2500, FASS, AFE Stage I, MBRP 4" Turbo-Back, Edge Juice w/Attitide)
Purchased June 07 as 2nd owner with 37007 miles on the ticker.
ben762 is offline
