Old 10-05-2008, 08:27 PM   #280 (permalink)
patracy
Super Moderator
patracy's Avatar
If you ran it slow enough I'm certain it would. I mixed up a heavy emulsion and was seeing the water beginning to bead up. This stuff was nasty, way worse than anything you'd run. Let gravity do the work for you on that though. Time is your friend when it comes to this.
1999 2500 4x4 Club Cab Sport. ADRENALINE/pulse , BHAF, FBD 150 sticks, Tunnel Ram Intake plate, Byrd's intake Horn, HE351 retrofit, Hamilton 110lb valve springs, A1 head studs, 5" FBD exhaust, Isspro Boost & Drive pressure gauges, fuel pressure gauge, Mallory Comp 250 pump, 1/2" big line kit, Draw straw, TC lockup switch, Stealth VP plate, BD TC, BD VB, Billet input, Derale pan. 462hp and 920ft-lbs 11/14/09, I know I can get 500hp...
patracy is offline
