Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 89-93 Tech Articles
89-93 Tech Articles Tech Articles for the 89-93 12V Dodge Cummins Diesel...NO ADVERTISING
Old 11-19-2007, 10:05 PM   #1 (permalink)
goosesgarage's Avatar
Alternator external regulator how to 89-02
Its common for the pcm to go bad a make the alternator not charge. I got tired of i and figured out how to use a ford regulator and make it work without the pcm.
Part numbers:
OE #9PZ10316A, E2PZ10316A, GR433, 544A, 540B
The regualter has four prongs (IASF) but only use three ASF.
Wiring
First find a spot to mount the regulater.Be sure the regulater is mounted grounded good before you turn the key on. (I mounted mine above the pcm)
A-goes to the +battery cable on the alternator (Large post)
S-goes to the ignition switch or wire thanks hot when the key is on
F- goes to one of the smaller post on the alternator (it doesent matter which one)
Be sure to unkook the two old wires on these small posts
On the other smaller post hook a wire on it than hook it up the the ground on the alternator
97 dodge 3500 drw nv4500 single cab western hauler with a few mods
http://www.neweradiesel.com
goosesgarage is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
