if you're vacuum pump springs a leak - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 89-93 Tech Articles
89-93 Tech Articles Tech Articles for the 89-93 12V Dodge Cummins Diesel...NO ADVERTISING
Old 01-28-2006, 07:08 PM   #1 (permalink)
swank's Avatar
take a close look at where the oil's coming out. if it's at the red arrow, all your going to need is a new o-ring . found this out last night. i was losing 3-4 qts of oil in 2hrs drive time. got the seal/gasket/o-ring kit from cummins for 7 bucks and started taking things apart. when i separated the set-up at the red arrow (good place to start when everythings on the truck, only 2 bolts) i found that the o-ring was as brittle as hard candy. i took the vacuum pump completely off and investigated/cleaned it though. couldn't find where the seal would go on it, so i'm guessing it goes somewhere near the blue arrow. put the new o-ring on, bolted 'er back together and surprise! no more leak. soaked the underside with simple green for a while and then down to the car wash to get rid of the few GALLONS of oil under there. problem solved.
dave
pic here
93w350. twins.
truck pics
swank is offline   Reply With Quote
The Following User Says Thank You to swank For This Useful Post:
dodge12v (12-20-2010)
Old 01-30-2006, 09:33 AM   #2 (permalink)
UPNSMOKE's Avatar
Yes The Seal Goes At The Blue Arrow. It Seals The P/s Pump Coupler
2009 DODGE 2500 MEGACAB LARIMIE MINI MAXX EGR & DPF DELETE 5" EXHAUST
SOLD SILVER 2002 ETC 3500 4X4
JOHNSON DIESEL PERFORMANCE432-559-8901
UPNSMOKE is offline   Reply With Quote
Old 01-30-2006, 12:52 PM   #3 (permalink)
swank's Avatar
btw, here's the cummins part # for the "kit" (gasket, seal, o-ring) that should cost about $7.42 straight from cummins. $50 or so if you let mopar put their sticker over the cummins one on the EXACT SAME package.
4089742
93w350. twins.
truck pics
Beansandslaw (02-19-2011)
Old 01-30-2006, 09:50 PM   #4 (permalink)
Paccool's Avatar
Swank, Thanks to you and Tom for the info you have entered in the first gen tech section. All info is great, need more!
The only thing I would add on this one is to be careful when removing the seal from inside the vacumn pump housing. It (the housing) is aluminum and scores easy.
How do I know??? Don't ask!
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HDcrew cab 4x4, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, Banks intake, ported turbo mouthpiece. Predator programmer, Autometer EGT and boost gauges.
Paccool is offline   Reply With Quote
Old 01-31-2006, 12:15 AM   #5 (permalink)
swank's Avatar
i heard about that, but didn't have to do it on mine.
93w350. twins.
truck pics
Old 02-01-2006, 06:56 AM   #6 (permalink)
Free spirit
R-N-R's Avatar
Mine is seeping (slow drip) from the red arrow. Thanks for the info and the P/N!
'02 2500, 2WD, 4.10, QC LB Cap, Bilstein, Gauges, DTT, IIS
R-N-R is offline   Reply With Quote
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
