Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 89-93 Tech Articles
89-93 Tech Articles Tech Articles for the 89-93 12V Dodge Cummins Diesel...NO ADVERTISING
Old 01-23-2006, 09:34 AM   #1 (permalink)
Admin
Paccool's Avatar
possible injection pump recall information - NS
The following was supplied by Pastor Bob.
Early 1st Gen injector pump recall number (605)
A shipment of pumps in 1991 from a supplier were developing problems by 1994 so they did a recall to replace them. If you don't have a truck maunfactured within this timeline then the recall does not pertain to you......Unless your pump was replaced under warranty before 1994 in which case they would again replace your pump because the faulty pumps were also installed during the warranty period from dealer stock.
If you are a good debater and you replaced you pump in the 90's at a dealer, I don't believe they have any way to prove that you didnt get a bad pump Pumps manufactured between March and September, 1991 (date codes 163 through 169) without an infinity symbol on the data plate or tag (rebuilt pumps). On the pumps after this, the data plates and tags have an infinity symbol on the right side.
This is what the service tech is looking for. It says, "If date code is 163 through 169 and no infinity symbol is present, replace pump". This info comes from page 3 of the actual Recall service procedure. The specific pump in question was Bosch # 0 460 426 184, Cummins # 3918991.They were replaced with Bosch 0 460 426 205, Cummins 3923346.
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler installed 10/06, 3" IC lines.
"if you're not part of the solution, you're part of the problem"
Paccool is offline   Reply With Quote
Old 02-10-2007, 10:41 AM   #2 (permalink)
RCTS's Avatar
Help, my truck has one of the replaced pumps
I want to buy a new pump for my truck as I want a backup, I take my truck on long road trips and if I have pump problems I want to have all the parts in my truck if I need them.
Where is the best place to buy a new Bosch 0 460 426 205, Cummins 3923346?
I found one on ebay but I stopped bidding at 1500 because I did not know if was one of the recalled pumps that was hanging around a dealership parts department.
Also does anyone have a copy of the step procedure required to change the pump on my 92 12 Valve 6B Dodge engine?
Thanks in advance.
Reg
RCTS is offline   Reply With Quote
Old 03-16-2007, 07:17 PM   #3 (permalink)
RCTS- I'd say look on the pump and see if it has a date code of 163 thru 169. I looked, and mine is outside this realm. It is a CPL 1579, so it is supposed to have the 205 pump, but it is a 184.
Daniel
dpuckett is offline   Reply With Quote
Old 03-16-2007, 10:14 PM   #4 (permalink)
RCTS's Avatar
Thanks Guys. I purchased a brand new one from Reliable Parts, fantastic service!
One of the members said that Reliable parts did good job, well I purchased a brand new pump from them, fantastic service and price.
Thanks for the tip.
Reg
RCTS CANADA Calgary, Alberta
http://www.monsterhorsepower.com/
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
