Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 89-93 Tech Articles
89-93 Tech Articles Tech Articles for the 89-93 12V Dodge Cummins Diesel...NO ADVERTISING
Old 02-07-2007, 05:01 PM   #1 (permalink)
Admin
Paccool's Avatar
Oil Pressure Readings - NS
I have a Cummins Operation and maintenance manual for B series engines. For a 160 HP B5.9 used for automotive use:
Minimum allowable pressure at idle = 10 PSI
Minimum allowable pressure at rated RPM = 30PSI
Regulated pressure = 65 PSI
"Regulated pressure" is the pressure the bypass spring opens up and puts oil back into the crankcase. This should be the highest pressure you see on a gauge.
BTW, the manual was printed in 93 but the engines are the same basic engine from 89 to 93. Shows 5 different HP engines from the 160 HP the way up to 230 HP and the oil pressures are all the same.
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HD, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, modified air box, ported turbo mouthpiece. Predator programmer.
Paccool is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
