Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > 89-93 Tech Articles
89-93 Tech Articles Tech Articles for the 89-93 12V Dodge Cummins Diesel...NO ADVERTISING
Old 07-03-2006, 03:31 PM   #13 (permalink)
Originally Posted by Greenleaf
Norm
Just ignore the previous post by PB. Someone should notify his aid he escaped from his room again.
A head bolt holds the rocker tower to the top of the head. Just pull that thing and clean it and it's hole up really good like and coat the bolt threads and head with light coat of oil. Make sure no oil is between the bottom of the rocker tower and the head. Put the small rocker tower bolt in place but tighten only after the head bolt. Clean the small bolt in same manner.
Torque it.
BTW when you remove a head it's generally ok to reuse the bolts. The gasket kit will contain a gauge to measure the stretch.
I feel like I'm learning engines all over again. (I guess I am!) Thank you for all your help.
93 W250, 5.9L cummins, Auto, 4WD. K&N Air Filter and a strait pipe. Injector Pump tweaked. Timing bumped up 1/8". Home made propane injection and a little bit of grindage on the fuel delivery pin!
BigNorm is offline   Reply With Quote
Old 03-23-2007, 07:29 AM   #14 (permalink)
Jarbo440's Avatar
Question about the location of the high idle screw?
Is this the same screw that I have seen called just the idle screw on several diagrams posted around here? Thank you for your help.
Jarbo440 is offline   Reply With Quote
Old 03-25-2007, 09:49 PM   #15 (permalink)
Jarbo440's Avatar
Could someone please give me a quick description as to where this governor screw is located on the pump? Thank you.
92 W250 - 7" Lift, 36/12.5-16.5s, Muffler delete w/ 4" straight pipe from there back.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
