in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
1989-1993 1st Gen Dodge 5.9L 12V Cummins
89-93 Powertrain
Follow Forum
Create Thread
UPDATE:
Images posted between 02/20/24 and 02/25/24 may not work, re-uploading the image by editing your post should fix this
More info found HERE
March's Cummins of the Month
is now open for entries!
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 350
Go to page
Go
350
Sticky
New Powertrain Posting Rules
tryNto
Apr 20, 2022
Locked
0
2K
Apr 20, 2022
by
tryNto
Sticky
Link to 1st Gen Tech articles
9297oldram
Apr 24, 2021
Locked
0
6K
Apr 24, 2021
by
9297oldram
Low Stall Converter
sdeeter19555
6h ago
0
55
6h ago
by
sdeeter19555
He341 wastegate for 12 valve
92cumminsprobms
1d ago
Redirect
N/A
B
BHAF Warning!!
Brucetafer
Aug 12, 2019
38
3K
3d ago
by
Motorhead_22
S
Salvaged 6B deleted Turbo (?!) in my steel boat, VE pump QUESTIONS!
sojournercd28
3d ago
3d ago
by
tobylou8
R
10 speed behind a 12 Valve. Ever seen it?
RustyRedneck
Aug 8, 2019
33K
4d ago
by
Jimmy N.
P
Back to the beginning crank no start
portpaulchristensen
Feb 9, 2024
43
1K
5d ago
by
9297oldram
S
Adapter Plate Question
searcher
5d ago
4
178
5d ago
by
s10010001
Starter Differences
sdeeter19555
Mar 4, 2024
14
331
5d ago
by
Werner1111
S
Trnsmission leak from around output splines
searcher
Feb 25, 2024
9
329
6d ago
by
searcher
Leaf Spring Shackle Mounting Bracket CAD file(Solidworks file)
Gabe Teg
6d ago
0
136
6d ago
by
Gabe Teg
Unbolting Torque Converter From Flexplate
Bryce_Wragg06
7d ago
8
215
6d ago
by
Ruderunner
W
93 w250 Cummins No fuel
Willytyrone
Jan 6, 2024
37
808
6d ago
by
Willytyrone
I
Loose Timing Housing Bolts
IL farmer
Mar 7, 2024
5
191
7d ago
by
IL farmer
I
Replacement Injection pumps for 1992 12V w intercooler?
IL farmer
Feb 23, 2024
20
502
Mar 10, 2024
by
Sheep Herder
Battery not charging. RPM tach not working
sammcneil1256
Feb 6, 2023
18
2K
Mar 9, 2024
by
9297oldram
Runs rough
loudhornsrule
Feb 20, 2024
91
944
Mar 7, 2024
by
loudhornsrule
Bosch DGK-121 availability
Raven23
Feb 27, 2024
14
357
Mar 3, 2024
by
Werner1111
N
VE pump case pressure regulator
NWOperator
Feb 28, 2024
16
352
Mar 3, 2024
by
Werner1111
Cylinder head interchangeably?
Wrought-Iron-W250
Mar 2, 2024
9
267
Mar 3, 2024
by
Mikey-KE7LBB
Leaking headgasket
Wrought-Iron-W250
Feb 29, 2024
7
268
Mar 1, 2024
by
Mikey-KE7LBB
N
Turning power screw in makes truck die
NWOperator
Mar 1, 2024
Mar 1, 2024
by
NWOperator
91.5 CTD Jumped 1 tooth & M&H dynamic spacer am I too far advanced
SnarF07
Sep 18, 2020
7
957
Mar 1, 2024
by
NWOperator
N
Timing skipped a tooth now bogs up high HELP!
NWOperator
Feb 28, 2024
Feb 28, 2024
by
NWOperator
H1C performance
92cumminsprobms
Feb 24, 2024
6
241
Feb 25, 2024
by
sdeeter19555
Chugging & 12V Down
VE_Lord
Jan 19, 2024
18
557
Feb 24, 2024
by
VE_Lord
M
Looking for Speedometer Adaptor Shaft
mark460
Feb 22, 2024
4
181
Feb 24, 2024
by
tobylou8
P
Crank no start
portpaulchristensen
Feb 9, 2024
Redirect
N/A
A518/46rh rebiuld performance kit
Maren Boot
Feb 22, 2024
7
281
Feb 23, 2024
by
Rug_Trucker
Proper 1/2-20 wheel studs for the W350
Jtb5.9
Dec 7, 2023
15
645
Feb 22, 2024
by
David Ivory
B
1989 DW250 Crank no start. Need Help!!!
batting500
Feb 25, 2011
20K
Feb 19, 2024
by
Boosted 1st gen BAT
Retorquing studs
Stpackard
Feb 16, 2024
3
239
Feb 19, 2024
by
Stpackard
M
new crankshaft sensor, new pcm, still no overdrive, no a/c, no alternator charge, etc
moparman13045
Jul 9, 2013
9
10K
Feb 17, 2024
by
TarzanLeeroy
C
Anyone know the thread size for the FSS?
cj3waker
Feb 15, 2024
4
185
Feb 16, 2024
by
cj3waker
Killer Dowel Pin Dimensions
Gabe Teg
Feb 12, 2024
8
316
Feb 15, 2024
by
thrashingcows
C
12 valve ve pump 6 speed swap
cooper.l
Feb 5, 2024
20
589
Feb 15, 2024
by
thrashingcows
1
1 of 350
Go to page
Go
350
89-93 Powertrain
138.7K
posts
44.3M
views
Discussion on what directly makes the truck move: Engine, Transmission, Driveshaft, Differentials and Axles
Show Less
Join Community
Grow Your Business
Forum Staff
View All
steve05ram360
Super Moderator
9297oldram
Super Moderator
rghavana
Moderator
Top Contributors this Month
View All
9297oldram
loudhornsrule
P
portpaulchristensen
Recommended Communities
AVS Forum
1M+ members
SkyscraperCity
880K+ members
Deals Forum
40+ members
Home
Forums
