93 cummins will not prime. Please help - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 02-17-2014, 11:15 PM Thread Starter
I have a 1993 CTD W250 that was sitting for about a month due to a problem with the battery. I have now solved that problem, but the truck will not crank. It doesn't seem to be getting fuel. I have tried hand pumping the lift pump & tried the bleed screw & cracked the lines. I have fuel coming from 4 of the 6 lines, but can't get fuel to come out of the last two. I have spent the past 6 hours trying everything I know to get fuel so the truck will crank.
Can anybody give me any other advice to help? I'm sorry I don't know a lot about these engines, so if there is any other information I need to post please let me know.
The truck was running great when parked & has a little over half a tank of diesel in it.
Thanks
Brian
93MSCummins is offline
post #2 of 14 (permalink) Old 02-17-2014, 11:24 PM
I'd change the filter......make sure battery is good and charged....hold the pedal to the floor as you turn it over and see if it will then...you might have to keep starter engaged for awhile?
chargin72 is offline
post #3 of 14 (permalink) Old 02-17-2014, 11:28 PM Thread Starter
I put a brand new battery on it and had the throttle to the floor each time I tried to crank it. I will try the filter the next time I have time to work on it.
Thanks
post #4 of 14 (permalink) Old 02-17-2014, 11:53 PM
do the injectors that are getting fuel, squirting fuel?
post #5 of 14 (permalink) Old 02-17-2014, 11:55 PM
Moderator
9297oldram's Avatar
When you tried to bleed the filter did anything come out?
When you was trying to bleed the injectors did you open all of them?
Is your FSS wire on and getting voltage with the key on?
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
post #6 of 14 (permalink) Old 02-18-2014, 12:03 AM Thread Starter
I was only able to get air bubbles out of the bleed screw. The 4 injector lines that were getting fuel had a good stream of fuel, but I never did get fuel to even seep out of the other two. The FSS had a good connection & voltage was good. I still don't think I was getting fuel pressure since I was only getting air from the bleed screw.
post #7 of 14 (permalink) Old 02-18-2014, 12:11 AM
Moderator
9297oldram's Avatar
As long as your getting air bubbles out the bleeder you won't get it to start. Either your low on fuel, broken or cracked fuel line or the fuel module is bad.
Once you can manually pump the Lp and get no air bubbles out the bleeder then you can start bleeding the injectors. Until then all your doing is filling the IP with air.
92 D250 parted out
post #8 of 14 (permalink) Old 02-18-2014, 12:15 AM
if its just a stream, they should be squirting to the fenders....Id still change filter and if that dont do it then lift pump might be done
post #9 of 14 (permalink) Old 02-18-2014, 12:21 AM
Moderator
9297oldram's Avatar
Until he gets his air in the fuel problem fixed changing the filter or LP isn't going to change anything.
92 D250 parted out
post #10 of 14 (permalink) Old 02-18-2014, 10:43 AM Thread Starter
Just to be clear. I first tried cracking open the bleed screw and manually pumping the lift pump. After about 200 pumps it started to blow bubbles. Then after about 200 more pumps it quit, but no fuel ever came out. I continued to pump it until I had pumped 1,100 times total, and yes I counted. At this point I had not noticed any change (no air bubbles and no fuel leaking from the bleed screw).
Right or wrong, I moved to the injector lines and cracked them open 1 at a time and was able to get fuel out of 4 of the 6. I then decided to open all of them and got the same result as opening one at a time.
While 4 of the 6 were squirting fuel, it definitely did not have enough pressure to spray to the fender as someone above stated it should.
I was off work yesterday afternoon and spent about 6 hours doing all of this. I'm not sure when I'll get another chance to work on it. But when I do where do you suggest I start back? Should I go back to the bleed screw and pump until fuel comes out of the bleed screw?
I appreciate the help and will post any changes to the situation.
Thanks
post #11 of 14 (permalink) Old 02-18-2014, 10:52 AM
Moderator
9297oldram's Avatar
If you pumped the LP 1,100 times and no fuel came out the bleeder for the filter then you have a problem.
No fuel in the tank.
Bad LP.
Plugged fuel filter.
Broken or cracked fuel line.
Problem with the fuel tank module.
After about 10 pumps you should have had fuel coming out the bleeder for the filter.
Until your getting fuel out the bleeder all your doing is pushing air into the IP with what little fuel was in there. When the filter is full of fuel then it will come out the bleeder.
92 D250 parted out
post #12 of 14 (permalink) Old 02-18-2014, 11:11 AM Thread Starter
That was what I was afraid you would say. I was just hoping everything was ok since it was running fine when I parked it.
Since I know the fuel tank has over a half a tank of diesel in it, is there a way to narrow down the other four items on your list?
Should I just change the fuel filter to eliminate it?
This is my first diesel, much less 1st Gen Cummins so I'm learning as I go. I've had the truck a little over two years with very few problems, but I was able to solve them by reading these forums. This time I finally joined the forum and I appreciate your patience with me.
