It was over a year ago and I don't have the papers from 2007 in the office right now but...
If I remember right it was around $480 for everything. Completely rebuilt 1991 thru 1995 3 piece vacuum pump, oil feed line, pump and PS gaskets, pump mounting studs and nuts, and I had to pay a core charge because I didn't have a 91 - 95 core and my 1989 original 1989 canister type vacuum pump was smashed.
The upgrade come in when you originally have a 1989 type vacuum pump. It uses two external vacuum canisters mounted onto the vacuum pump. These pumps use ball bearings (as I understand it) and the ball bearings are a threat to your engine much the way the killer dowel pin is. As if that were not enough of a problem, the flanges that mount the canisters to the pump are bad about snapping off of the pump, which is what happened to mine.
Nobody I could find even deals with those early kind of pumps, they all recommended swapping up to the next newer style pump, a fully mechanical pump with no external canisters. To do so, you need to install an additional oil feed line from the engine block to the vacuum pump and also saw part of the throttle mounting assembly out of the way of the PS pump since the newer type vacuum pump is a little longer than the older style pump.
It was pretty easy once I bought the turn key upgrade and started installing everything. I also put a new PS pump on while I was down there as recommended. I took pictures of some of the steps if anyone wants me to post them. I got a good shot of the oil line installed.
I think the guys I bought my pump and everything from were
FIXINRAMS.COM but I would have to go thru my records to be 100% sure of that and the exact cost back in Spring 2007. In any case the guys I used were great and hooked me up with some original mounting studs and nuts since mine were damaged by the previous owner.
If naming that business is a forum violation, sorry. Not trying to be slick, just trying to give complete information in my answer.
Thanks and hope this was some help, Mike.
