Radiator coolant - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-21-2013, 12:15 PM Thread Starter
Radiator coolant
So I've gotten mixed reviews on running coolant/water. Vs SCA can anyone give me a good answer on what to run and how much of each. Thank you in advance!
cumminskid95 is offline
post #2 of 9 (permalink) Old 12-22-2013, 01:30 AM
SCA? What is that?
FWIW I use a 50/50 mix of prestone original in all my vehicles and have no cooling problems even with mainly 30 yr old parts.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #3 of 9 (permalink) Old 12-22-2013, 01:57 AM
Rescue Tower
Shainer's Avatar
Just regular coolant. I have same results as Rude. Now if I were running an engine with cylinder liners I would keep track of the SCA.
Custom pinstriped Power Wheel. I started out with very little... I still have most of it. Feel free to PM me anytime.
Shainer is offline
post #4 of 9 (permalink) Old 12-22-2013, 02:25 AM
Comrade General's Avatar
Ive never heard of SCA either
1992 w150 d60/70 4.10s xover and many more.,
1993 w250 getrag, 374 spring, THD pin, THD comp inj 6x.013, SBDD clutch, timing spacer, 60mm hx35, HT3B, D80, 3.54, 35"s, 6in lift, AirDog, studs, o-ringed and many more
Comrade General is offline
post #5 of 9 (permalink) Old 12-22-2013, 09:25 AM Thread Starter
SCA is a formula made especially for heavy duty diesels such as tractor trailers construction etc. But now alot of guys are running it in there trucks
post #6 of 9 (permalink) Old 12-22-2013, 11:03 AM
There is an additive to stop electrolysis so it does't corrode freeze plugs ect. rapidly.
Fritzcat is offline
post #7 of 9 (permalink) Old 12-22-2013, 11:11 AM
Rescue Tower
Shainer's Avatar
Its purpose is to limit or stop wet liner pitting, which the ISB does not have.
Shainer is offline
post #8 of 9 (permalink) Old 12-22-2013, 01:24 PM
Would SCA be like Nalcool or something?
post #9 of 9 (permalink) Old 12-22-2013, 01:40 PM
Rescue Tower
Shainer's Avatar
Come on guys. I like answering questions, but you're in front of a computer with access to the same internet as I. Search SCA (supplemental coolant additive). Use google, don't expect this forum to have all answers.
I looked up Nalcool. Yes it apears to be an SCA. It is not needed in the Cummins ISB. Plain green antifreeze has done me right for over 200k miles. Change it at the correct intervals and do something else with your spare time.
NALCOOL Product Line from Nalco
More SCA is not better either.
What is SCA and how it affects an engine?s life? - Parts & Power Ltd
Shainer is offline
