Transfer case vibration noise - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 11-23-2013, 11:20 PM Thread Starter
12valvedriver's Avatar
So today i was hauling a load of scrap to the yard. Not real heavy, i weighed in at just under 12k. On the way over i noticed a vibration noise coming through the shifter on the transfer case. It continued all day even unloaded. It starts at about 25 mph. It is there when u let off, there when you shift, there when your coasting...always. Unless you are under 25 mph. Any ideas? Transfer case need a rebuild?
'97-5" straight #100 ff, 19*, 4k gsk, AD II 165, valair dd clutch, 1-3/8" billet input, ARP studs, 60#, BD Super B over s475, 024's, Mayville WI best 5x14's,
'90-4" exhaust, kdp killed, pacbrake, 60 lb springs
12valvedriver is online now
post #2 of 24 (permalink) Old 11-24-2013, 12:37 AM
cummin's crewcab builder
iTrader Score: 11 reviews
U joint's or carrier bearing transfer case is usually bullet proof
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto ,hx35 with a 14 non wg housing ,366 spring and fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #3 of 24 (permalink) Old 11-24-2013, 02:53 AM Thread Starter
I wonder if its the carrier bearing. Will i feel slop if i reach up there and move it?
post #4 of 24 (permalink) Old 11-24-2013, 04:47 PM
bmoeller's Avatar
Carrier bearing is mounted in rubber, so there will be a bit of movement. It is bad, you should be able to tell pretty easy.
Check the u-joints and make sure the nuts on the yoke are tight.
'93 W350 CC 5spd 500k miles.
'82 W350 crewcab dually, CTD, 6spd, 4wd
SOLD '92 W250 '97 3500, '99 3500
bmoeller is offline
post #5 of 24 (permalink) Old 11-24-2013, 08:48 PM Thread Starter
Well being a reg cab, there is no carrier bearing. I didnt realize that until i crawled under it. There is some slop in the driveline, but it doesnt seem to be in the u joints. U can turn it a bit either direction and it sounds like where the gears engage
post #6 of 24 (permalink) Old 11-25-2013, 02:25 AM
bmoeller's Avatar
Could still have a dry u-joint that is stiff. Seen that before. Even if it is only in one bearing cup.
If not obvious, you'll need to pull the driveshaft and turn them by hand.
bmoeller is offline
The Following User Says Thank You to bmoeller For This Useful Post:
12valvedriver (11-25-2013)
post #7 of 24 (permalink) Old 11-25-2013, 11:48 AM Thread Starter
I will crawl under and take a closer look tonight. Throw some grease jn there and be sure its all tight then take it for a spin. Ill check fluid levels in the transfer case as well.
Any chance this could be a transmission bearing of some kind?
post #8 of 24 (permalink) Old 11-25-2013, 03:47 PM Thread Starter
Also, I should be specific in that it sounds like a fairly high frequency vibration....the closest comparison I can think of would be maybe like a cell phone vibrating
post #9 of 24 (permalink) Old 11-25-2013, 04:21 PM
At that frequency it's almost certainly a driveshaft. Does it make a difference if the front hubs are locked or unlocked? That can narrow it down to front or rear shaft.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #10 of 24 (permalink) Old 11-25-2013, 05:45 PM
It may sound stupid but when in vibration starts reach over and sort of jiggle the t case lever and see if it stops. My truck has a rattle or vibration noise from that area and its just the t case linkage vibrating.
1992 W250,Getrag,NP205, 229,000, Dowel pin killed, 1.5 turns on fuel screw,366 spring, M&H timing spacer at stock timing mark, HE351CW, power stroke IC,3" tubes.
quietmike is offline
post #11 of 24 (permalink) Old 11-25-2013, 06:21 PM Thread Starter
It is all in 2wd without the hubs in.
I have tried the jiggle the handle trick. There is another rattle that that fixes, but this one is a new noise, and jiggle the handle trick didn't work.
post #12 of 24 (permalink) Old 11-26-2013, 10:44 AM
spencerk252's Avatar
mine does it and its just slop in the linkage makign it vibrate
91.5 W250- 2" lift, 33s, Dennys Stage 2, Turned up pump, HX35
spencerk252 is offline
