Smoke Screw - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 08-02-2008, 06:53 PM Thread Starter
Smoke Screw
I have been backing out the smoke screw on the top of my injector pump. It is located under a brass cap on top of the pump. So far I have backed it out 1 1/4 turns. My fuel milage went from 22 mpg to 26.5 mpg. I am afraid of going to far and ruining something. Does anyone know anything about this.
Jim2 is offline
post #2 of 25 (permalink) Old 08-02-2008, 06:56 PM
what kind of truck?
2006 Dodge Ram 2500 CTD QC LB Blue two tone silver. Farmboys Diesel 5" Straight
R.I.P. 2001 Dodge Ram 2500
tredz6 is offline
post #3 of 25 (permalink) Old 08-02-2008, 08:09 PM Thread Starter
1991 dodge standard cab, cummins, 5 speed, 2 weel drive
Jim2 is offline
post #4 of 25 (permalink) Old 08-02-2008, 09:53 PM
PToombs's Avatar
You won't hurt anything unless it falls out. If it does that, just put it back in. That screw preloads the fuel cone that is pushed down by the boost pressure. More boost = more fuel.
Pete
'92 D350, sticks, air, pipes, 388 hp, 799tq
'97 2500, ECLB
PToombs is offline
post #5 of 25 (permalink) Old 08-03-2008, 12:42 AM
does this work the same on newer generations?
tredz6 is offline
post #6 of 25 (permalink) Old 08-03-2008, 12:54 AM
pipeliner71's Avatar
yea want to know more on this one to and would it work on mine
2010 crew cab ram 3500 4x4 h&s with delete
pipeliner71 is offline
post #7 of 25 (permalink) Old 08-03-2008, 03:23 AM
gear jammer 91"'s Avatar
The smoke screw is an adjustment on the bosh ve injection pump in first gen rams, so, no it won't work on newer trucks. Sorry. Jim2, if you turn your star wheel up it could also help you gain mileage. It would make your truck kinda doggy until the turbo spools though.
2016 RAM 2500 Crew Cab 4x4 6.4 Hemi
95 x-cab lb 4x4 5spd Sold, 01 LB7 Sold, 96 x-cab lb 5spd Sold, 91 W250, 436HP 968FT-LBs Sold.
gear jammer 91" is offline
post #8 of 25 (permalink) Old 08-03-2008, 12:24 PM Thread Starter
Thanks for the info. I will keep playing with it and keep you posted.
Jim2 is offline
post #9 of 25 (permalink) Old 08-13-2008, 08:31 AM Thread Starter
I just backed the smoke screw out another 1/2 turn, then I took the cover off the top of the pump to adjust the star wheel. Now it looks like I've got the smoke screw out as far as it's worth going. The diaphram can hit the top of the housing. I turned the star wheel 1/4 turn CCW. I'll write back in about a week to let you know what my milage is. It also looks like I might be able to turn that off-set cone in the bottom to help.
Jim2 is offline
post #10 of 25 (permalink) Old 08-13-2008, 09:04 PM
you're 100% right about being able to turn the fuel pin. Just put it so the shallowest part of the cone is facing the front of the truck.
post #11 of 25 (permalink) Old 08-23-2008, 08:25 AM Thread Starter
I just filled up last night, and checked my milage. With the smoke screw backed out all the way, the shallow side of the cone facing the front of the engine, the starwheel turned 1/2 turn CCW, and conservative driving I got 28.3 MPG! Now I think I'll start playing with the full fuel srew.
Jim2 is offline
post #12 of 25 (permalink) Old 08-23-2008, 11:34 AM
unixcowboy's Avatar
Well - there goes the conservative driving
2011 Long Bed Crew 3500 w/6 Alcoas set up towing a 40' 5th wheel RV. Custom front bumper/grille guard and rear fender protection
unixcowboy is offline
