Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (http://www.cumminsforum.com/forum/)
-   89-93 Powertrain (http://www.cumminsforum.com/forum/89-93-powertrain/)
-   -   Help Wanted (http://www.cumminsforum.com/forum/89-93-powertrain/736985-help-wanted.html)
-BROESKY- 10-27-2013 12:46 AM
1989 Dodge dually bent rims
Can someone tell me what size of wheel studs i have on my 1989 Dodge 350 dually as well as thread count. I wanting to mount a set of Ford rims on the front off a mid 90's F-350. Are the rims on mid 90's Fords or older Chev duallys hub-centering? My front rims are bent and i would like to go with a set of hub centering rims as mine are lug centering and have the coined stud holes.
Thanks
Thunder_wagon 10-27-2013 06:30 AM
Ford didn't go to hub centric wheels until superdutys came out. The lug pattern also changed to a metric, 8x170 if I remember right. Your truck is 8x6.5 inches. The 90s ford wheels will work. The wheel studs are 9/16 but I can't remember the thread on first gens.
Ruderunner 10-28-2013 06:59 AM
Dodge dually prior to 91 or so (with the change to internal lockouts) used 5/8 wheel studs. Your 89 should be 5/8.
Are you sure your front rims are bent? These had a problem with running off center and the fix was to use 2 regular (not flanged) lugs to center the rim while torquing it down.
-BROESKY- 10-28-2013 09:39 PM
Yeah the one rim has a folded over lip on the edge and the other one is warped. There also pitted and corroded. I just want to replace them with another set of steel ones that are in nice shape as well as new tires.
-BROESKY- 10-28-2013 09:42 PM
Yeah the one rim has a folded over lip on the edge and the other one is warped. There also pitted and corroded. I just want to replace them with another set of steel ones that are in nice shape as well as new tires. I can't find anyone that can source a new set of rims with the coined stud holes. I got a set of ford rims but I'm not sure how to mount them correctly.
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
