Transfer case fluid - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 08-02-2013, 07:25 PM Thread Starter
Brad_Bibbee's Avatar
Transfer case fluid
Ok, so I just put my newly rebuilt transmission and goreend converter in my truck. I'm ready to install the transfer case. and I'm wanting to change the fluid. Should I run an ATF transmission fluid or go with a gear oil? Also whats the oil capacity? Its a gear driven transfer and my truck is a 91.5 with an A518. Any info is always greatly appreciated.
92 D250 NV4500 HT3B/HE351CW DFI SAC 5x0.012 366 Denny T PS Intercooler 3.07s
91 W250 Built A518
05 Dmax LLY zf6 EFI Live
Brad_Bibbee is offline
post #2 of 5 (permalink) Old 08-02-2013, 10:21 PM
W350_1992's Avatar
I use 10w30 with some lucas.
'92 w350 Club Cab 5spd 3.54, D80 DRW with 2nd gen rear suspension, Gauges, VGT, Flow Honed injectors, Mild IP adjustments, BHAF, High Vol Piston Pump, Water/Methanol, KSB spacer, Ground Stock pin
'97 3500 2wd ext cab dually bed- currently no engine or transmission, future project
W350_1992 is offline
The Following User Says Thank You to W350_1992 For This Useful Post:
Brad_Bibbee (08-07-2013)
post #3 of 5 (permalink) Old 08-02-2013, 10:38 PM
cummin's crewcab builder
iTrader Score: 11 reviews
I use 75-90 wt and it takes I want to say 4 qt's
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto ,hx35 with a 14 non wg housing ,366 spring and fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #4 of 5 (permalink) Old 08-04-2013, 01:07 PM
440trk's Avatar
According to the 1991 FSM:
For the NP205
Multi-purpose gear oil (API GL-5) or engine oil (API SG, SG/CD, or SG/CE)
I've personally never seen a 205 that used ATF.
I've run Gear lube or straight 30wt engine oil, and never had a problem. As long as you adhere to the above oil specs, you should be fine.
Mike(440trk)
91 W250 LE ~235k miles, 727, 3.07's w/limited slip rear
440trk is offline
The Following User Says Thank You to 440trk For This Useful Post:
post #5 of 5 (permalink) Old 08-07-2013, 07:29 PM Thread Starter
Thanks again, I'll try 4 quarts.
91 W250 Built A518
