Battery - Dodge Cummins Diesel Forum
post #1 of 18 (permalink) Old 06-04-2013, 07:38 PM Thread Starter
grizzlypaugh's Avatar
Battery
What is a solid battery for our cummins?
1993 D350 Dually club cab 5speed BHAF 4in exhaust
grizzlypaugh is offline
post #2 of 18 (permalink) Old 06-04-2013, 07:51 PM
cummin's crewcab builder
iTrader Score: 11 reviews
1000 CCA check with Napa they should have 1 for you .
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto ,hx35 with a 14 non wg housing ,366 spring and fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
post #3 of 18 (permalink) Old 06-04-2013, 07:56 PM Thread Starter
Thankyou. Ill give napa a call.
post #4 of 18 (permalink) Old 06-04-2013, 10:10 PM
W350_1992's Avatar
X2 on Napa. Bought one for my truck a while back and like it real well so far
'92 w350 5spd 3.54, D80 DRW, airbags, THD LP and pin, 366 spring, water/meth, VGT, honed stock injectors, mild VE adjustments, KSB spacer, gauges
W350_1992 is offline
post #5 of 18 (permalink) Old 06-04-2013, 10:50 PM
I bought a 900 CCA or thereabouts Interstate Battery from Rocky Mountain Cummins for about $140 last year. With 10% off Military Discount.
No issues thus far.
89 W250, 5 speed, KDP killed.
97 2500,ex cab, 5 speed, killed that KDP too.
Lowshooter is offline
post #6 of 18 (permalink) Old 06-04-2013, 11:02 PM
666
x3 or what ever on napa, never gives any trouble and mine hasnt corroded like the junk i see at work everyday.
1991.5 d350 getrag drw. denny t stage 2 pin, 4 inch diamond eye turbo back, 235 85 16 bfgs. gds 60mm compressor wheel, 16cm exhaust housing, bhaf, J&I flatbed
666 is offline
post #7 of 18 (permalink) Old 06-05-2013, 11:31 AM
Jossi's Avatar
Napa. Or Check if you want to save some money, get a 1000 CCA Interstate.... its big, ugly and heavy. Also, Tractor supply has some good batteries, but 1000 CCA seems to be the best....the faster you spin it over, the quicker it lites off. That means less wear and tear on your starter.
"----If it ain't loud, lowered, long, and flatblack....an ain't belchin' black smoke...an don't have at least 1 Turbo....it ain't about S***!"-SCREAMIN' METAL
Jossi is offline
post #8 of 18 (permalink) Old 06-05-2013, 06:26 PM
W350_1992's Avatar
Same here, the prevoius 3 batteries before the one I have installed all leaked like crazy, this Napa is dry as can be
post #9 of 18 (permalink) Old 06-10-2013, 09:00 PM
KoolKauf's Avatar
Guy at my napa recommended a red top optuim or what ever they are dry cell and he said he can get some special one for me thats big enough to start our trucks. Price wasnt to crazy high either and from what iv heard they work fine in all other trucks
Evan Kaufman, 1992 12valve W250 466xxx km, Modified stock air box, star wheel turned up, gound stock fuel pin, ported stock air horn
KoolKauf is offline
post #10 of 18 (permalink) Old 06-11-2013, 10:27 AM
ClassA4x4's Avatar
If you don't wanna pay too much, try Autozone's Group 31 950CCA for $99 i believe. I have one and it's doing fine. Make sure to read the replacement warranty.
77 Dodge Xplorer 307 Frank Ind 26-ft 4x4 Class A Motorhome 1st Gen '93 Cummins swapped in, 47RH/NP241, stock turbo, PS intercooler, ground fuel pin, starwheel, fuel screw turned, 366 spring, BHAF, M&H DTA, 4" downpipe, DNA muffler, ARB Lockers, 17500# winch.
ClassA4x4 is offline
post #11 of 18 (permalink) Old 06-12-2013, 05:37 AM
Mike337's Avatar
I run Interstate.
1989 Ramcharger with 93 Cummins 6BT.
1992 Ramcharger with 93 Cummins 6BT.
1996 2500 Cummins 12v.
Mike337 is offline
post #12 of 18 (permalink) Old 06-13-2013, 08:39 AM
19cummins92's Avatar
Napa brand 1475 cca commercial battery. It's longer, but bolts right in, and is only $120.
'92 W350 cc/sb project, '89 W250, '91 W250, '90 D350,'92 D250... Its all junk!
19cummins92 is offline
