Best mods for 1993 towing truck!! - Dodge Cummins Diesel Forum
post #1 of 20 (permalink) Old 02-07-2013, 05:10 PM Thread Starter
I have a 1993 d350 dually thats getting an engine overhaul, 6x18's, Denny t II
Fuel pin, 3200 rmp spring, 4' turbo back exhaust, tweak pump, stainlessteel manifolds, fluidampr, twin horn intake (ram aire) , S&B air intake. The question is what is the best turbo for such mods and any advice on the mods I made or to be done for a towin/work truck??
Ltd's 350 is offline
The Following User Says Thank You to Ltd's 350 For This Useful Post:
John316 (05-13-2014)
post #2 of 20 (permalink) Old 02-07-2013, 06:24 PM
I've got a HE351 on my 92 D350, with a fuel pin and 4inch exhaust and love it.
ram09 is offline
post #3 of 20 (permalink) Old 02-07-2013, 06:47 PM Thread Starter
Thanks for your reply; Yes, i looked into it, but looking for something fancier!! I forgot that I also put a 14 mm rotory head for that ve pump, so lots of fuel going thru it!! They recommended me a 62/71/12 phatshaft, but looking for more advice.
post #4 of 20 (permalink) Old 02-09-2013, 12:27 AM Thread Starter
Red face
Anybody else, I would appreciate some help!! Thanks anyway
1993 D350 dually flatbed 6x18's, 14mm VE tweak, 518, 4' exhaust,3200 spr, denny's pin, Stainless Manifold, 2nd Gen horn,2nd Gen piston pump
post #5 of 20 (permalink) Old 02-09-2013, 07:31 AM
austinbrose's Avatar
That's an insane amount of fuel for a work truck, twins are probably your only choice.
1994 2500 Regular cab 5 spd 4x4 290,000 4k gsk, afc live, gauges ect. "stock-ish"
austinbrose is offline
The Following User Says Thank You to austinbrose For This Useful Post:
Ltd's 350 (02-10-2013)
post #6 of 20 (permalink) Old 02-09-2013, 12:01 PM
redtoy's Avatar
How well is your trans built? How heavy are the loads it will be pulling? I found out real quick that the 518 isn't happy pulling heavy with a turned up motor. Egts could also be an issue depending on the terrain you run.
I ended up dialing mine back till I can get a better (47rh or manual) trans in mine.
86 gmc k3500 3+3 tow pig with 92 cummins swap,4" diamond eye,6" lift,36" tires,4.10 gears,he351,6x10 vco,gm nv4500,13" south bend,meth inj, second gen intercooler,3200 gov spring,3" tubes,free pump mods,vintage air.
redtoy is offline
The Following User Says Thank You to redtoy For This Useful Post:
post #7 of 20 (permalink) Old 02-09-2013, 12:05 PM
mountianman69's Avatar
Yeah if you want lots of power and still be towable you have to have twins!
Sent from AutoGuide.com App
(Built by The Pit Stop) 2001 QCSB 4x4 35" Pro comps TWINS superB over S475 with CPP 7X12 SACs with lift Quad 4K Phantom2 guages AIRDOG 150(THE GOOD FITTINGS NOT THE CRAP ONES) Valair 800hp ceramic DD billet input shaft Hamilton push rods and Hamilton springs Stainless diesel twin kit (fits perfectly!!) stainless diesel adjustable waste gate And thanks to Optima 2 Brand spanking new Red tops as a truck warming gift!
Originally Posted by DieselDon16 View Post
Im not gonna be a Bachleor silly, Im gonna marry you!!
"Im Forever yoouuurrrsss, Faithfully.........Nick"
mountianman69 is offline
The Following User Says Thank You to mountianman69 For This Useful Post:
post #8 of 20 (permalink) Old 02-10-2013, 03:36 PM Thread Starter
The transmission I m getting is the same 518 but from monster transmissions, I wanted to upgrade to nv4500 but the conversion and everything Im putting in was going to be to much time and there are not so many reliable mecanics on this part of the world. Im gonna pull close to 9k o more!! I live in south texas so not many hills down here. Twins?? $$ I didnt want to but what would you guys recommend???
post #9 of 20 (permalink) Old 02-10-2013, 03:48 PM
666
those injectors seem awful big for a work/towing truck, your going to need lots of air to keep from just perforating a piston or two. Twins are probably your best bet or just go back to stock/mild because 9k isnt all that heavy and a stock truck will move it just might be a little slow.
1991.5 d350 getrag drw. denny t stage 2 pin, 4 inch diamond eye turbo back, 235 85 16 bfgs. gds 60mm compressor wheel, 16cm exhaust housing, bhaf, J&I flatbed
666 is offline
post #10 of 20 (permalink) Old 02-10-2013, 06:12 PM
ATV24/7's Avatar
With those injectors id say compound turbos are about your only option
08. Mega dually 4x4 68rfe. 99 RC dually nv4500 4x4 90 W350 RC Flatbed 4x4 727-sold. 07.5 QCSB 4x4 g56-sold
ATV24/7 is offline
post #11 of 20 (permalink) Old 02-10-2013, 07:48 PM Thread Starter
Well stock is not an option, so what twin set up could work best for towing???
post #12 of 20 (permalink) Old 02-10-2013, 07:51 PM Thread Starter
What do you recommend?
