Does it hurt to leave your truck plugged in! - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 01-23-2013, 07:23 AM Thread Starter
I have my truck stored in my unheated Pole Barn and I have been leaving it plugged in the last couple days because its been real cold 0 degrees here (It starts faster then my new car) just wondering if I should leave it plugged in or ??? I like to go out and start it everyday or so and let it run for 15-20 minutes.... will it hurt?? anyone else do this??
jackpinesavage is offline
post #2 of 15 (permalink) Old 01-23-2013, 07:56 AM
I'd be ok with leaving it plugged in but I wouldn't start it an let it idle. Don't bother starting unless you're going to run it.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #3 of 15 (permalink) Old 01-23-2013, 09:33 AM
mthomp1's Avatar
When I do decide to plug in, I use a timer that runs the bock heater two hours before I wake up for work. When the idea came to me, I thought I was being original, but it looks as if a lot of others use them as well. That's an option for you.
2001 Ram 2500, 24 valve, 47RE, 4x4, 3.55, short bed, quad cab, all stock
1996 Ram 3500 cab & chassis, 12 valve, NV4500, 4.10, flatbed, single cab, all stock
mthomp1 is offline
post #4 of 15 (permalink) Old 01-23-2013, 09:35 AM
Won't hurt anything but the electric bill. They take a lot of power and it's a terrible waste if you're not using it.
Steve g
91 D-250 LE Bone stock so far 615,000 kms and everything working just like the factory intended with no POTS, pans, string, jumper wires or ball point pen springs.
Steve g is offline
post #5 of 15 (permalink) Old 01-23-2013, 09:40 AM
garagepeople's Avatar
Won't hurt a thing, except you wallet..
We have contractors that leave machines plugged in 24/7 from the first freeze to mid fall. I'm sure they are not worried about the light bill tho.
07.5 QC/SB, 6.7, SB3250, G56 <delvac 50w> 4X4< nv271, 5inch SS silverline tbe, sinister egr delete, airaid intake, SJ67 on#1, ccv,gutted/rerouted ...smoke switch...
2009 VW jetta TDI 6speed manual. 96 ECLB 12valve auto/ats commander
garagepeople is offline
post #6 of 15 (permalink) Old 01-23-2013, 09:40 AM
dB Zac's Avatar
If two hours before start up seems to make it start easy, that's fine. I also agree that starting it and idling the truck for 15 min every day, does more harm then good. Cummins says you should only warm up via idle till the idle speed smooths out, then continue warm up with low rpm driving due to the fact Cummins dissipate heat so well. So don't start it if you aren't gonna drive it
Zac Soares. 92 Dodge Ext Cab M/T Dually,Super B 57/64/14, BHAF, 2nd gen intercooler, Denny T stage 1 pin,Pump turned up a bit, 366 gov spring, timing spacer, 5X12 sprayers, 4" exhaust, 350HP clutch.
dB Zac is offline
post #7 of 15 (permalink) Old 01-23-2013, 10:41 AM
CumminsBoy94's Avatar
Steve g
Someone did a huge review on here about that awhile ago I think and they said it really doesn't affect you electric bill much at all. They had a bunch of calculations and other crap. Not sure how true it is, but sounded legit.
1991 Dodge Ram W250 4x4 I/C Cummins Turbo Diesel, A518, HX35, 230k miles, pump turned up, Borgeson steering shaft, 2.5" Skyjacker Lift, Denny T Stage 1, Diamond Eye 4"
CumminsBoy94 is offline
post #8 of 15 (permalink) Old 01-23-2013, 11:28 AM
1STGENFARMBOY's Avatar
all heaters are a dead short and use alot of amps/watts/money, when you plug one in and it's cold enough to make it come on you can hear and see an arch whitch means there are quite a few amps beeing turned on.
i love pluging mine in the night before i drive it when it's cold, you have instant heat and the ol cummins is sooooo much happier.
if it costs an extra 30.00 a month during the cold months it's worth it just in saving ware and tear on the engine.
Dar
93 W250, A518, 3.54, DDP 4's, 16cm housing, 60mm Gillett, all pump mods, P/S intercooler, Tim W cooler tubes, carter 4601, 366 spring, denny t pin, homemade BHFF, BHAF, 1/8in bump, 4in DP to 5in , gauges,
1STGENFARMBOY is offline
post #9 of 15 (permalink) Old 01-23-2013, 12:54 PM
cornman369's Avatar
I agree with these guys, shouldnt hurt overnight. 24/7 seems pointless, I use a timer to flip it on 2 hours before I leave work work in the morning.
Though I have heard storys about them melting the plug off the cord on the block side, the kid had it plugged in 24/7 because his cooling system was all water....
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #10 of 15 (permalink) Old 01-23-2013, 01:02 PM
Moderator
9297oldram's Avatar
Where did you find a timer that would handle the heater?
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/18.5
9297oldram is online now
post #11 of 15 (permalink) Old 01-23-2013, 01:08 PM
STONR's Avatar
Walmart. Generic rotary-style timer that has the ground prong on it. Hasn't failed me on 2 different trucks over the last ~5yrs.
+1 on not starting the truck unless you are going to actually drive it. At an idle all you are doing is somewhat warming the motor. Great recipe for generating condensation and carbon buildup, and even a little bit of cylinder washdown.
2005 2500 QCLB, BigHorn, 48RE/3.73, Edge Juice w/ CTS + Turbo Timer, TransGo Shift Kit, GDP 20/2 fuel filter on the frame, ISSPro EV2 Oil and LP Pressure in the cubby hole, Custom Diesel Steering Box Brace
STONR is offline
The Following User Says Thank You to STONR For This Useful Post:
9297oldram (01-23-2013)
post #12 of 15 (permalink) Old 01-23-2013, 01:13 PM
Moderator
9297oldram's Avatar
I have a couple Walmart timers but they are only 2 prong 1875 watt, I'll have to check again next time i'm there.
