Fuel pump adjustment - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 12-31-2012, 12:15 AM Thread Starter
Hey guys... new to diesel trucks LOVE my Dodge. 1992 D250, bone stock except intake is K&n, also has an intercooler i believe. I've heard about adjusting the fuel pump... can anyone walk me through this like explaining it to a child? i would like to blow a little bit more smoke when i touch the pedal :P
tonkaturbo is offline
post #2 of 10 (permalink) Old 12-31-2012, 01:38 AM
92betsy's Avatar
smoke bad mmm k.
Dustin
92' ext cab d350 dually
92betsy is offline
The Following User Says Thank You to 92betsy For This Useful Post:
9297oldram (12-31-2012)
post #3 of 10 (permalink) Old 12-31-2012, 08:22 AM
Moderator
9297oldram's Avatar
I heard a turbo delete was the best thing for some smoke. You can control it with your pedal the harder you push it the more smoke, push the pedal easy and you'll have light smoke.
But you better have some extra cash for fuel because your mileage won't be very good, smoke is dollars out the tail pipe.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is offline
The Following User Says Thank You to 9297oldram For This Useful Post:
Andrewtt12 (12-31-2012)
post #4 of 10 (permalink) Old 12-31-2012, 08:35 AM
W350_1992's Avatar
Smoke = power(wasted to the atmosphere), I unhooked one of my I/C boots a while back and I could make plenty of smoke. I could also make some crazy EGT's in neutral!
In all seriousness, tuning for more smoke is exactly that- tuning for more smoke. Smoke does not equal power.
'92 w350 5spd 3.54, D80 DRW, airbags, THD LP and pin, 366 spring, water/meth, VGT, SDX 5x12's, mild VE adjustments, KSB spacer, gauges
W350_1992 is offline
The Following User Says Thank You to W350_1992 For This Useful Post:
post #5 of 10 (permalink) Old 12-31-2012, 02:50 PM Thread Starter
I understand the whole smoke out the exhaust is money out of my pocket.. i spend 700 a month in fuel... a little more wont kill me. anyone able to help out with how to do so ?
post #6 of 10 (permalink) Old 12-31-2012, 02:53 PM
CumminsBoy94's Avatar
Are you trying to slowly kill your engine ooorrrrrrrrr what? More smoke just means more money wasted, and lost power since you'll be flooding the turbo more. I tuned my truck to smoke less and it runs much better than when it did smoke.
If you still want it to smoke, good luck, nobody is gonna help you give diesels an even worse rep.
1991 Dodge Ram W250 4x4 I/C Cummins Turbo Diesel, A518, HX35, 230k miles, pump turned up, Borgeson steering shaft, 2.5" Skyjacker Lift, Denny T Stage 1, Diamond Eye 4"
CumminsBoy94 is offline
The Following User Says Thank You to CumminsBoy94 For This Useful Post:
post #7 of 10 (permalink) Old 01-01-2013, 07:21 AM
Dodgeram.org/tech/dsl/more_power/Power_ve.htm
Heed the warnings about overdoing it.
92 d250 le creampuff, rc auto and stone stock.
Ruderunner is offline
post #8 of 10 (permalink) Old 01-01-2013, 11:49 AM
There Is a video on you tube where the guy walks you through turning up ur pump. Search first gen cummins pump tune.
91 W250 single cab 4x4, 727auto Denny-T stage 2, 4" dp to 5" straight pipe, 1/8 timing bump 366 spring,
2004 2500 Qclb 4x4 Nv5600. Stock
jerrylittle78 is offline
post #9 of 10 (permalink) Old 01-01-2013, 02:08 PM Thread Starter
wow thanks this goes over all of the different parts. thanks i appreciate that. and i don't want to overdo it. just a little adjustments to see what i can get.
post #10 of 10 (permalink) Old 01-01-2013, 10:06 PM
DodgeW250's Avatar
Here is what you can do if want a lot smoke.... 1st-buy a turbo delete kit. second-do an intercooler delete that should hep you out some. third-get some 5,000hp injectors, that should really flood your engine out. P.S. if you hate to do a turbo delete just rap your air filter up several wally-world sacks and that should do the trick just fine. after all of theese mods you will be spending about $1000 worth of diesel.
1999 2500 5spd. RCLB 2WD leveled, Dana 80 3:55/Mag-hytech, EJWA/Hot unlock, DDP 50hp, FASS 150, Pusher Intake horn, BD boots S&B CAI, 4" TB Straight pipe/8" tip LEDs, HIDs, Circle M Bumper.
DodgeW250 is offline
