Performance Transmission Rebuild - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 05-13-2012, 08:06 PM Thread Starter
BlaineKaiser450's Avatar
Hi, I have a 1993 W350 auto with about 90k on it, and I plan on eventually making a 400ish horsepower truck out of it, but being 17 I can only do so much with the money I have. I am selling my dirtbike to get some cash, and the first thing I plan on building is the transmission. I was just wondering what parts I should look at, while also keeping cost as relative as possible. I am looking for a pretty sturdy low stall torque converter, which one? Also regarding shift kits, I want it to have a more aggressive shift, but remain a true auto, I'm not looking for a manual valve body. My intention is to get all of the parts together, then bring it to a shop to put together for me to try and save a little money, and my knowlege on the internals of a 518 is minimal. Also, what would be the average price to rebuild the transfer case? I also plan on doing the U-joints while its apart, but I have a solid idea of how expensive that should be. I know that the transfer case is most likely not necessery, but I am big on preventative maintnence so I belive that it would be a good thing to at least look at.
Thanks, Blaine
1993 White Dodge W350 Dually, Built 46rh, IP Mods, Hungry Diesel Fuel Pin, Stiffer AFC Spring, 62/68/12 FMW, DAP 5x14s, Raptor 150 Lift Pump, 4 Inch Exhaust, 120K, 3.55s, 6 Inch Lift, ORD Crossover Steering, 35x12.5x20s
BlaineKaiser450 is offline
post #2 of 15 (permalink) Old 05-13-2012, 09:15 PM
Hummin'Cummins90's Avatar
if it aint broke don't fix it IMO
90' D350, G360 conversion, HX35, denny t stg II, 366 spring, fuel turned up, timing to the head, BHAF
06' 3500, G56, all stock, rig truck
Hummin'Cummins90 is offline
post #3 of 15 (permalink) Old 05-13-2012, 09:23 PM
Baxter's Avatar
I have to agree. To a point. A good rebuild and a torque converter will go a long way, from what I hear.
Google Mechanic Extraordinaire
92 W250, Automagic, 4" lift, 37's, BHAF, 4" TBE, Tweaked Pump, Denny T, 366, HVLPLP, TPS MIA, Timing Bump, HE351CW, P/S I/C.
Baxter is offline
The Following User Says Thank You to Baxter For This Useful Post:
Hummin'Cummins90 (05-13-2012)
post #4 of 15 (permalink) Old 05-13-2012, 09:35 PM Thread Starter
Well I'm building the transmission to handle more power for the future sooooo...
post #5 of 15 (permalink) Old 05-13-2012, 10:09 PM
i would continue to drive it and continue modding the truck until it slips, but im one of those people who wants to get the most out of something before i replace it. one guy on here is putting way over 300hp through his 518 and its still stock, these trannies will take quit a bit of power. if i were you i would just get a hd rebuild kit, and a goerend torque converter.
post #6 of 15 (permalink) Old 05-14-2012, 04:32 PM Thread Starter
Right, well what torque converter and shift kit would be the best for my needs? The truck is mostly just going to be a hot rod, it rarely tows anything other than a ski boat. I'm just trying to collect all the info I can!
post #7 of 15 (permalink) Old 05-15-2012, 11:30 PM Thread Starter
So no ones built their transmission?
post #8 of 15 (permalink) Old 05-16-2012, 12:50 AM
did mine awhile back -
but that was at about 350 000 kms. Tugged a 32 foot trailer all over BC and Alberta - a few trip into the US. Stock was just fine - until it slipped. rebuilt it with the shift body, better quality clutch packs and a low stall (700 rpm) converter. In hind sight i would do it again but look for a higher stall converter; I have to slip it into neutral at a long red light to give the trans a rest. This truck came with the factory auxilary cooler (infront of the left rear wheel) - and I would recommend extra cooling. its been about 200 000 kms since the rebuild - no sign of ageing or failure.
93 W250, 16 cc turbo, air box, 3200 rpm spring, fuel pin, Bosch 190 injectors, tweaked pump, Tach, 4 inch exhaust, 4 speed auto with low stall TC & still thumping after 460 000 km.
1100winger is offline
post #9 of 15 (permalink) Old 05-16-2012, 12:02 PM
i built my 46rh, and it was a waste of money... get a manual or build a 47rh conversion... TRUST ME... if you want a built tranny buy mine.. ill sell it to you for the price of the build, 3200 bucks...
91.5 D350 Flatbed Dually, HE351CW, Built 46RH, 4.10 Gears, Denny T Pin, Timing Spacer, 3200 Spring, BHAF, 4" Exhaust, Glowshift 3n1, Borgeson Extreme Steering Shaft, 6K HID, K3LA Train Horn, 12000 Pound Winch.
Brucetafer is offline
post #10 of 15 (permalink) Old 05-16-2012, 01:02 PM
moparbubba's Avatar
I built my A518 i blew mine rolled the sprag busted the case.... anyway i did....
Alto red eagle clutches kolene steels kevlar bands sonnax shift kit b&m double deep pan harden intermediate shaft
(i picked up a 4x4 trans from a friend cause my case was shot only 91.5 92 use that sprag set up 93 is heavier or so im told... but his had "upgraded " hardened" shafts idk if thats true or not but i used em)
Turned up line pressure big cooler out front a better tq should have got a lower stall speed....
Sent from my DROIDX
Ole shakey 92 D250 lots of junk bolted on
New shakey 2010 2500 crew cab long bed smarty jr s&b intake diamond eye exhaust ect ect...
moparbubba is offline
post #11 of 15 (permalink) Old 05-16-2012, 01:02 PM
dB Zac's Avatar
agreed!
Zac Soares. 92 Dodge Ext Cab M/T Dually,Super B 57/64/14, BHAF, 2nd gen intercooler, Denny T stage 1 pin,Pump turned up a bit, 366 gov spring, timing spacer, 5X12 sprayers, 4" exhaust, 350HP clutch.
dB Zac is offline
post #12 of 15 (permalink) Old 05-16-2012, 01:21 PM
cummin's crewcab builder
iTrader Score: 11 reviews
Contact a member on here his name is Fred Swanson he know's transmission's and know's what work's
Newest toy 2017 VW Golf Altrack TSI Sold 2013 Durango bit the dust 9-04-14
RIP Speedy the 67 vw died a very hot Death 5-17-2010 New toy 1985 crewcab longbed 4x4 conversion with a 93 cummin's and built 47rh with compushift mini controlled auto sxe62/70 turbo 6x13 injector's full 4 in Diamond Eye Exhaust ,366 spring and THD fuel pin .along with Boost and Pyro gauges and Tach .
simplysmn is offline
