Help with Loosing Overdrive. - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 04-16-2012, 08:53 PM   #1 (permalink)
greg_a_morton's Avatar
Guys My 1993 dodge has been a great truck but I have had to play with several things since I got it. I kept loosing fluid and finally got me a new b&m aluminum pan and still losing fluid. I finally figured it out as the O rings that was on the dipstick tube. I have not lost overdrive in over 2 months until today. What is the first things I need to check since the tranny is fairly new and full of fluid as checked in neutral. Thanks for the help in advance, Greg.
1967 mercury 350 cab & chassis, 7.3idi ats turbo, c6, 3.73 dana 60 gear vendors OD running on 19.5s
1993 dodge cab&chassis 5.9 autoOD 3.54s rolling low and slow!
greg_a_morton is offline   Reply With Quote
Old 04-17-2012, 12:53 PM   #2 (permalink)
chumasn's Avatar
Check the solenoid on transmission.
98.5 ~24V~ 4X4 2500 qcsb. Automatic. 3in Straight Piped. BHAF. Fuel Pressure, Boost, EGT Gauges. FRRP. Silencer Ring Removed. Turnover Ball. Tinted Windows. Linex Bed Liner. Tow Mirrors. Runnin 2 Stroke Oil.
chumasn is offline   Reply With Quote
Old 04-17-2012, 07:36 PM   #3 (permalink)
had same problem with my 92 w 350. tried distance sensor, anti lock brake sensor, crank sensor, had trans rebuilt, still dropped out of overdrive, finally read service manual and studied wire diagrams, found wire harness on drivers side of engine stretched around steel fuel line rubbed through, (if you follow crank sensor harness from front to back you'll find it) I pulled wires off and repaired and overdrive has worked flawless since.
cheeseburger63 is offline   Reply With Quote
Old 04-17-2012, 07:47 PM   #4 (permalink)
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 7 reviews
Click the link below. Go threw the instructions for testing and setting the TPS. Then post back with what you find.
PDR Diesel Inc. The turbo diesel performance specialists! - 1st Gen TPS
93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, B&W flatbed
Old 04-18-2012, 06:15 PM   #5 (permalink)
thanks for the info guys. The truck seems to never loose od in the mornings, just in the evenings?? All the visible wires under the truck around the tranny seem to be in good shape. I have a extra tps from a parts truck in case that ends up being the problem. I need to get this figured out before june as I am going on a 300 mile trip and 2200rpm at 55 gets old. The newer common rail cummins sound better at the higher rpm. The old cummins seem to like 1400-1800 rpm the best.
