89-93 PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
I have a 93 4x4 club cab with an automatic transmission. A few days ago I was driving and the transmission started shifting weird and the truck would buck when slowing down. I havent really had the chance to take a look at it nor do I know a whole lot about automatics. I perfer manual transmissions and I have been thinking about swapping from automatic to manual for a while now and if my transmission is shot then I might do so. I have a friend who helped swap transmissions in another 1st gen and said if I chose to swap he would help me. I would like to get get some advice on the swap and possibly a list of what all I would need.
Thanks
Hammer time. Are you saying that the parts aren't easily accessible or what? I'm looking to buy a 1st gen 90 model 350 it's an auto but I wanted a 5speed. These trucks are becoming hard to find!! Thanks in advance
98 auto ex cab lwb stock silincer gone
05 3500 4dr drw STOCK WTB 1st gen 5spd.......
Just swap straight to an nv4500 you can buy pretty much the whole kit from advance adapters for under 3k. Too bad you didn't decide this last week I sold everything out of mine for an entire conversion except the t case for 500 bucks
89 RC on shortened 92 diesel frame - NV4500 w/dual disc/4.10s on 37s. - Self built pump, "hot screw", lots of timing, True high volume low pressure lift pump, he351cw, flow honed stock inj., Studs/O-rings,- 414rwhp - 10/01/2011
im comparing this all to my GETRAG swap.........i spent 1200 bucks on a 5 speed parts truck minus axles(drivetrain only-everything else seen better days) and spent maybe 400 bucks extra to get EVERYTHING else needed to row some gears....Its easier to buy a complete truck with the right bolts,brackets,pedal assy,crossmember(if needed),flywheel+bolts etc.....i had a 727 in my truck and i know both the rag and 727 are the same length give or take and the driveshafts but im not to certain if the o/d trans is the same splines.you may need new shafts worst case scenario...fyi the clutch plastic hydro line from master to slave is discontinued from dodge but there is aftermarket threaded fittings and braided line you can buy from summit...the engine adapter plate may be different on your truck your truck to a getrag and the starter.. this is why im saying get a whole truck because theres just alot of little things that will take longer to attain than just buying a junk truck...if you go for a nv4500 theres going to be more involved
89 CUMMINS-SOLD
06 crew f250 6.0 4"turbo back mbrp exhaust,sct tuner,airdog 165,xdp fuel sump,afe stage 2 intake,xdp coolant filter moto metal 943 20's on 35" nitto terra grapplers-DD
Pick a tranny, everything else is allot more simple than you think.
The hydraulics are the same on all 1st gen and 2nd gen trucks
The t-case physically bolts up from any year and any trans. However all manuals have a 29 spline and all autos have a 23 spline. There is a company that makes a 29 spline to 23 spline sleeve so you can use any case behind any year dodge tranny.
The starters are diff from 1st gen to 2nd gen
The engine backing plate is diff from 1st gen to 2nd gen.
That is about all things needed to know that I can think of.
No they are not. The line and slave cylinder are the same. The push rod on the master cylinder is longer due to the mounting difference between the to generations.
You sir are correct. The rod underneath the dash to the clutch pedal is a diff. length. Also after a little research in 98-02 the the master cylinder to firewall part I guess is a little different.
look for a fellow named jim clark on ebay. sold me everything, rebuilt nv 4500, south bend clutch & flywheel, bellhousing engine plate, adapter for t case, full of oil and shiped to my door $3,100. only things i had to get was the slave master and stater. slave and master i ordered from rock auto 120$ starter from napa 100$ both for second gen.
i had to cut the rod on the master cylinder and weld in an adjustable rod for extra length.
best investment since i got the truck!!
1991, w250, non ic, 727 auto...scratch that, nv4500, 4wd, reg cab, 265 mtrs,
mods-straight pipe, minor fuel pin shave, spring retainer turned 360*, full fuel 2 turns in. happy......for now.
honestly for 3 grand id rather spend some more money and buy the whole truck and just drive that...i swapped my truck because its my toy and i did it on a budget...
89 CUMMINS-SOLD
