Fuel leak on injection pump - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 04-02-2012, 02:09 PM Thread Starter
Hudler's Avatar
there is a little rubber tube that runs out of the pump on the back side and i think it is like an over pressure valve of some sort...but anyway it is spraying fuel put of ther when i drive but not at idle or even then i rev it up...it only leaks or sprays when im on the road
1990 Stock W350, 360 getrag, pump mods, straight pipe
Hudler is offline
post #2 of 8 (permalink) Old 04-02-2012, 05:03 PM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
The O-ring is leaking on the pin that rides on the fuel pin.
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
The Following User Says Thank You to Philip For This Useful Post:
Hudler (04-16-2012)
post #3 of 8 (permalink) Old 04-02-2012, 11:52 PM
Classic problem when you start messing with the fuel pin.
93 W250 LE Club Cab, AT, 3.91 Sure Grip, DE 4"exh, Cooler Tubz, BHAF, Gauges, POD's, M&H timing spacer, Gillette Diesel fuel pin & 60cm compressor, Star wheel turned, Power screw maxed, KDP and case bolts fixed, WVO conversion, Skyjacker, Rancho's
Dieselluvr is offline
post #4 of 8 (permalink) Old 04-16-2012, 02:54 PM Thread Starter
Hudler's Avatar
how hard is it to replace and should i be worried about anything else in the pump...might as well replace anything else if i have to get into the pump
Hudler is offline
post #5 of 8 (permalink) Old 04-16-2012, 03:17 PM
Fred D's Avatar
its not that hard to replace, i just did one. if you can do a gov. spring, you can do the fuel pin o-ring. here is a post to help you out.
Fix That Leaking Fuel Pin - Midwest Diesel Connection
1988 ramcharger w/ 1993 12v and 5 spd getrag, phoenix friction stage 4 clutch, denny t stage 2, s300 over a schwitzer 4lhr-753, DAP 5x.013's, 3200 spring, 140 gph lift pump, mighty diesel head bolts, Glowshift 3-in-1 gauge
Fred D is offline
post #6 of 8 (permalink) Old 04-16-2012, 03:24 PM
Moderator
9297oldram's Avatar
Fred D Where hid you get your seal kit from, and a part No.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod
9297oldram is offline
post #7 of 8 (permalink) Old 04-16-2012, 03:33 PM
Fred D's Avatar
funny story on that. I got the kit on ebay, a full reseal kit it said with the 3200 gov spring. Well I looked for the seal small enough for the pin and there wasnt one in there that would fit the pin snugly, they were all too big. So luckily I have a kit of o-rings any size imagineable and got lucky as there was one in there that fit. I believe the dimensions for the o-ring are on the thread i had posted.
Fred D is offline
post #8 of 8 (permalink) Old 04-17-2012, 01:56 PM Thread Starter
Hudler's Avatar
i have a kit like that too, ill probably do a gov spring and denny t fuel pin while im at it
Hudler is offline
