Fan clutch left or right hand thread?? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 03-05-2012, 01:44 AM Thread Starter
Shakes's Avatar
Is the fan clutch right or left hand thread??
W250, Compounds s472 over s362 62/65-12, THD comp 83lph injectors, 60#'s, ported and O ringed head, dps 3 pc manifold, 366 spring, M3 pin, Front and Rear Lockers, 4.10's, cross over hydro assist hi steer, custom lift w/44" Super Swampers!!!
Shakes is offline
post #2 of 6 (permalink) Old 03-05-2012, 02:07 AM
I'm almost positive it's LH thread. Rotating the wrench counterclockwise ,as viewed from the front of the engine, tightens the nut..
1992 D350, forged crank, HD rods, fuel injected, turbocharged, intercooled, 19 - 1 compression, and gear driven camshaft Cummins engine
. Getrag 360 Trans ,4.10 rearend w/powerlock.
mikey89014 is offline
post #3 of 6 (permalink) Old 03-05-2012, 02:20 AM
Left hand thread
1991 350 4X4 5 Speed he351vgt with brake 5x0.12 sdx injectors, 60#springs, 4" exhast, Holley black fuel pump, 366 spring, head poorted, pump mods, Gages, 190000 miles
Marty Z is offline
post #4 of 6 (permalink) Old 03-05-2012, 05:35 AM
Supporting Vendors
RCCUMMINS89's Avatar
Yep, does anyone on here have a trick for it??????????????
Just read the thread and it got me thinking... I had to take mine off a long time ago on another 1st gen and failed, so I actually paid someone to do it.
RCCUMMINS89 is offline
post #5 of 6 (permalink) Old 03-05-2012, 10:28 AM
Moderator
9297oldram's Avatar
I put a 1 3/8 wrench on it and smack the top of the wrench with a hammer and it will usually break loose. But one other time I had to heat the nut a little to get it loose.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is online now
post #6 of 6 (permalink) Old 03-05-2012, 11:21 AM Thread Starter
Shakes's Avatar
My Dakota I actually used an air hammer with a strait chisel in it to knock the nut loose.
I was sure my ctd was left but it was getting to be a long day in the shop do I decided to pack er in for the night before I created more work for myself.
Shakes is offline
