New carrier bearing vs one piece ds - Page 2 - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 03-02-2012, 05:58 AM   #13 (permalink)
absent_heart's Avatar
You're looking at the same cost either way, Dodge had it right with carrier in this case. The only reason to get rid of it is if you are extending your drive train.
93 D-250, NV4500 with US Gear Overdrive Unit, 3.54 Gears, 2WD, Stock Injectors and Turbo, Pump Set To 1250 max EGT, 4" Exhaust, Rear Disc Brake Conversion, Denny T Fuel Pin, Fuel pin spacer, Timing Bump (soon to be KSB spacer) , Cable Shutdown Club
absent_heart is offline   Reply With Quote
Old 03-02-2012, 05:17 PM   #14 (permalink)
12v-in93's Avatar
whats the rough cost of the bearing???
12v-in93 is offline   Reply With Quote
Old 03-05-2012, 04:32 PM   #15 (permalink)
VA Chapter President
5.9LDiesel's Avatar
personally, IF you do allot of towing or have a heavy foot then a two piece is a must. My rear end rolls almost 2 1/2 inch when i mash on the throttle or pulling a load. The slip joint helps allot... if i had a one piece... Id probably break something with all the slack in my rear end. I need traction bars...but need money first lol
92 W250//DAP 5x16's//Silver 64//Denny 1//4inch Diamond Eye//33's Nitto Terra/Fuel/Trans/Boost/EGT//KDP//TRE Trans//DDT converter 1200stall//TRE custom valve body//Borgeson Shaft//ARP studs//TRE O-Ringed//60lbs springs//Scheids 12MM IP//Air dog 2 165GPH//XDP Fuel Sump//Snow Stg2//CPP Traction Bars//Timing to the head// 418HP 780TQ
5.9LDiesel is offline   Reply With Quote
Old 03-05-2012, 04:59 PM   #16 (permalink)
no one has stated the obvious here PINION ANGLE sure go with a one piece if you like replacing u joints and dropping your drive shaft on main street
if your going with a one piece you will most likely need to upgrade to cv joints on the ends to handle the angle without any problems if the truck is lifted cv's are a must
92 w250 5-speed 300k+ miles 4" exhaust other than that bone stock
Nothin pulls like a cummins
my beast http://s1070.photobucket.com/albums/...250%20cummins/
humboldtbrad is offline   Reply With Quote
