In frame main bearing replacement - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 02-28-2012, 12:07 PM Thread Starter
bwgarrett56's Avatar
Can main bearings be replaced with the engine in the frame ?
I already have the pan off, engine jacked up. I think I can get to all of them for removal, but I'm worried that I won't be able to get them torqued from under the truck. Can't find anything on the forums to address this issue.
Any advise would be appreciated.
2001 nv5600 stock
bwgarrett56 is offline
post #2 of 26 (permalink) Old 02-28-2012, 08:19 PM
Not sure I'm following. If you can get them loose to replace them why wouldn't you be able to tighten them?
Steve g
91 D-250 LE Bone stock so far 615,000 kms and everything working just like the factory intended with no POTS, pans, string, jumper wires or ball point pen springs.
Steve g is offline
post #3 of 26 (permalink) Old 02-28-2012, 08:25 PM
Carrnutt's Avatar
Steve g
Well if you have to use swivels and the such, the torque won't be accurate.
'93 Dually 5 spd, Str8 pipe, gauges, LED dash, BHAF
'03 3500 DRW Laramie 5.9 SO, 48RE Auto, 4.10 Rear
Carrnutt is offline
post #4 of 26 (permalink) Old 02-28-2012, 09:33 PM Thread Starter
Steve g
Thanks Steve g
Yes I think I can get them all off but it looks like it might be tough with just a torque wrench on the assembly. I was hoping for any info from someone who has done this before. I am just a little worried about tackling this with the engine in the frame. I want accurate torque results.
2001 nv5600 stock
post #5 of 26 (permalink) Old 02-28-2012, 09:41 PM
Thanks Steve g
Torque values generally have a range of 10 to 15%, it's not that critical as long as you're in the range. Using a short socket is preferable, but it won't be a problem if you have to use a universal anyways. The torque will change very little through a universal joint. It's done all the time.
Steve g
Steve g is offline
The Following User Says Thank You to Steve g For This Useful Post:
bwgarrett56 (02-28-2012)
post #6 of 26 (permalink) Old 02-28-2012, 09:51 PM Thread Starter
Steve g
I havn't checked every bolt location for tool clearance but I will just have to dive into it. Got to get it done somehow.
2001 nv5600 stock
post #7 of 26 (permalink) Old 02-28-2012, 11:08 PM
Carrnutt's Avatar
Not to be a buster or anything, but, when it comes to internal engine torque specs. I am more apt to be as precise as possible. Now, something like mounting bolts for A/C, or front cover, pump, etc. I would have a lesser issue doing by feel, or even guessing.
Manufacturer specified torque for main caps is 129 ft. lbs. With +/- 10% would make the range from 116 up to 142 ft. lbs. and at +/-15%, from 109 up to 148 ft. lbs. I would be very uncomfortable with that big a discrepancy on my engine's main caps.
The length from the pivot point is the main effect on torque, so straight extensions, albeit, the shorter the better, affect it minimally, depending on the material of the extension, due to flex, and as long as they are held as close to 90* as possible.
However, universals and / or swivels have a serious effect on and make for very inconsistent torques, at least in my experience. I think it can be exponentially worse, considering the torque sequence recommended is in 3 stages, 45, 88, 129.
There are several reasons;
1. the actual "twist" in the swivel, the wrench will still click where you set it, however an amount of that torque will not be applied to the bolt / nut. So the wrench clicks at 129, but torque applied to the bolt / nut is closer to 110.
2. how steep the angle is may actually multiply the torque that the wrench "senses", thereby reducing the actual torque applied to the bolt / nut. (same affect as above).
3. length of distance between swivel and bolt if placed at end of wrench before any extension, or wrench if placed at the end of any extension, can place the pivot a significant distance from the wrench's calibrated point. Thereby multiplying the torque applied to the bolt. So the wrench clicks at 129, but torque at the bolt / nut could be closer to 150.
Now if we figure in the +/- 10% allowed tolerance, that can add up to a MetricCrapTon of difference.
After all that being said... you probably won't have any problems. The potential is there, and I wouldn't be doing it, unless I was unloading the truck.
But I fall back on the old saying, just because something is made, sold, used or done all the time, doesn't make it correct nor necessary.
THE ABOVE IS ENTIRELY MY OPINION. BASED ON MY EXPERIENCE, KNOWLEDGE AND INFORMATION I HAVE ACQUIRED.
Carrnutt is offline
The Following User Says Thank You to Carrnutt For This Useful Post:
post #8 of 26 (permalink) Old 02-28-2012, 11:25 PM Thread Starter
Thanks Carrnut,
Now I'm really feeling uneasy about this project.
I will be under that engine tomorrow to check every bolt for torque wrench clearance.
My other big issue is am I going to be able to pull the wrench 130# ??
Never torqued anything that much before
2001 nv5600 stock
post #9 of 26 (permalink) Old 02-28-2012, 11:44 PM
Carrnutt's Avatar
Sorry to make you uneasy, like I said odds are you won't have an issue. A 1/2 inch torque wrench shouldn't be too bad.
Umm... you're really gonna hate me now...
I was just looking at this in alldata and the crank weighs 123lb (55.3kg)
Carrnutt is offline
post #10 of 26 (permalink) Old 02-29-2012, 12:07 AM Thread Starter
I don't intend to remove the crank ??
with all due respect and no offense, " what were you thinking"
2001 nv5600 stock
post #11 of 26 (permalink) Old 02-29-2012, 12:15 AM
We're going to have to agree to disagree. There is no loss of torque from a twisting extension. Whatever torque you put in on one end is what comes out the other end. The shaft will twist and as long as it doesn't break at the point it stops twisting it then transfers the torque through to the other end. Google it. I did.
The u-joint will cause a plus, then a minus reading, but is very much dependant on the angle. What I've read says that if you have under 15* of angle you simply disregard it all together. There is even plenty of argument on the engineering forums about even that. Of course if you try to go through too sharp an angle it will bind up, but that's something different all together. And that would be in a cardon style universal. If you are using the pin and ball type used with impact sockets the change is even less.
Cummins is a little more specific about their torque specs. Most engine manufacturers you will see it written as something like 95-105. On those if you take the centre you will be perfectly fine.
I would always attempt to not use a universal and adding extensions with flex, while not making it less accurate, make it more work. You have to pull your torque wrench a lot further through this spongy area. I will use a 3/4" drive extension reduced to 1/2 if I have to use an extension for that reason.
I've been a journeyman doing this for a little short of 40 years and have never had an issue where I've had to use a swivel. And I use extensions all the time.
On a different, but related point, Cummins does some things a quite different, and I have to wonder why. I have never seen an engine that req'd the mains to be tightened in stages and in sequence (other than snugging them all down to ensure they're seated). What is the point of that. The caps fit flush against the block. The only crush is the slight bearing crush to seat the shells. It's not like a head gasket or an intake where clamping force needs to be even and force the gasket into position. It doesn't matter how much you tighten a main, it doesn't get any closer to the crank. The bolt torque has only to do with removing the stretch and reaching the point it won't come loose. Block distortion during tightening? You wouldn't think so in so heavy a block. I do lots of diesels, mostly ag and have done gas engines forever and have never come across that. Engines that use torque to yield bolts will do stages, but that it just to get you to the point of bolt stretch.
Steve g
Steve g is offline
nlneilson (02-29-2012)
post #12 of 26 (permalink) Old 02-29-2012, 01:00 AM
Carrnutt's Avatar
LOL, indeed.
The first pic link as well as my comment about the sequence being hard to see in the pic, got missed when I cut / pasted.
Carrnutt is offline
