dana 70 rebuild - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-12-2011, 12:00 AM Thread Starter
cumminsrule01's Avatar
dana 70 rebuild
ok so i blew up my rear end and took the spiders, carrier and ring and pinon out of it got a parts rear end that needs bearings and im wounding what is the shaft play for the pinon and is there any shiming for the carrier
93 dodge eston fuller fs4205a swap, ppump 230hp pump, raptor 150 lift pump, twins, and full 5inch exhaust limted slip, 7in stack,
cumminsrule01 is offline
post #2 of 7 (permalink) Old 12-12-2011, 06:50 AM
The pinion has no shaft play; the two bearings are shim'd to deliver a preload on the bearings. This preload is set by the resulting drag required to turn the shaft.
The carrier shims set not only the bearing preload but locate the carrier side-to-side for the backlash specification. The pinion headbearing shims set the depth of the pinion so it meshes with the ring gear properly.
cheers,
Douglas
1990 D250, NV5600, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07, HX35....IC soon
1991 D250, 16cm housing
Douglas2 is offline
The Following User Says Thank You to Douglas2 For This Useful Post:
cumminsrule01 (12-12-2011)
post #3 of 7 (permalink) Old 12-12-2011, 11:57 AM Thread Starter
myn dint have any shims
post #4 of 7 (permalink) Old 12-12-2011, 12:00 PM
Smoke12Vem's Avatar
Youll need to know how to measure and set up backlash and preload to set this new center section up correctly or you will be tearing it out quickly as well
98 3500, 166,000 5 spd, 11 plate, 4 in turbo back, pump tuning, pricol gauges,
90 W250, 137,000, auto, pump tuned, 3200gsk, 4 inch turbo back, pricol gauges, WEO, hx35 soon
Smoke12Vem is offline
post #5 of 7 (permalink) Old 12-12-2011, 01:36 PM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
I would suggest reading this PDF. Then decide if you think you can do this. Your first diff rebuild is normaly better to have an experienced person there to guide you. If you make mistakes he will correct them as needed. If not all your work will end up like your current axle.
http://www2.dana.com/pdf/5312-9.pdf
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
The Following User Says Thank You to Philip For This Useful Post:
post #6 of 7 (permalink) Old 12-12-2011, 05:57 PM
Philip speaks wisely...I didn't do the re-bearing on mine. Turned out to use only the OE shims, but if it didn't I would have been up that well-known creek w/o paddle.
cheers,
Douglas
Douglas2 is offline
post #7 of 7 (permalink) Old 12-12-2011, 09:15 PM Thread Starter
thanks this will help alot
