Oil recommendation for cold weather - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 10-17-2011, 09:18 AM Thread Starter
Well its getting to be that time of year...
What oil would you folks recommend for cold weather in the old 6BT?
I have been using Shell Rotella T 15w40 all summer, I change it and the filter every 5000kms.
15w40 is a bit too thick for these cold mornings we've been having recently.
What do you guys think, 5w40 too thin? My truck is my daily driver, just used for short trips no hauling during the winter months.
I live in a condo and have no access to a plugin for the block heater, so on really cold mornings I probably wont even use my truck.
Thanks
JoeFerg is offline
post #2 of 11 (permalink) Old 10-17-2011, 05:19 PM
Moderator
9297oldram's Avatar
I used Rotella 5W40 Syn. all last winter and truck started first try unplugged. I'm in N Indiana not as cold as you but was a colder than normal last winter. I tried to part the front of the truck out of the wind close to the building.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/18.5
9297oldram is offline
post #3 of 11 (permalink) Old 10-17-2011, 06:51 PM
tractors1952@hotmail.com's Avatar
Just run the 15/40, it will start fine, especially if you plug the truck in, which is always a good idea. I start plugging equipment in at 40 degrees. Colder in northern BC than you would normally get, and works fine.
Stock 93 12v reg cab 2wd 4:10 rear 5spd getrag synthetic gear oils, Pac brake and K&N air filter, 20 mpg(imp) grossing 16,500 lbs, gotta love that. Keremeos BC
tractors1952@hotmail.com is offline
post #4 of 11 (permalink) Old 10-18-2011, 12:54 PM Thread Starter
Cool, thanks, I'm going to change to Rotella 5w40 next oil change.
Hopefully we dont see too many 0 Fahenheit days this winter....
JoeFerg is offline
post #5 of 11 (permalink) Old 10-18-2011, 01:00 PM
Moderator
9297oldram's Avatar
Let me warn you you may see a few more oil leaks than using 15W40 I've gotten about 8,000 Miles on this oil and only added 2 quart at the most. I run synthetic in both my 92 and 97 and they both started good in cold weather.
post #6 of 11 (permalink) Old 10-18-2011, 01:12 PM Thread Starter
I've taken care of all my oil leaks....except for the valve cover gaskets. They are so easy to change, I should just do it one of these days.
I've done the rear main oil sean and pan gasket earlier this summer.
JoeFerg is offline
post #7 of 11 (permalink) Old 10-18-2011, 01:18 PM
Moderator
9297oldram's Avatar
If you have to replace your valve cover gaskets it would be a good time to adjust your valves.
post #8 of 11 (permalink) Old 10-18-2011, 01:53 PM
Left out in the cold's Avatar
Don't you K-nucks have access to a 0-40 synthetic?
Left out in the cold is offline
post #9 of 11 (permalink) Old 10-18-2011, 02:03 PM
Moderator
9297oldram's Avatar
Not that cold here.
post #10 of 11 (permalink) Old 10-18-2011, 11:12 PM
Does a synthetic 15w40 like Redline or AmZoil have a lower pour point than Rotella?
I just got my first diesel truck. 93 1 Ton. I use AmZoil truck oil in my gas small engines, and it makes rope starting that was zilch to unbelievable almost easy.
j_martin is offline
post #11 of 11 (permalink) Old 10-19-2011, 06:46 AM
hey-Hey!!!,
I run the Mobin 1 5W-40 in mine. Tried the Rotella 5W40 but it consumes that stuff( leaks are the same between the two ). Starting is easy, and that w/o waiting for the grid heater to cycle.
cheers,
Douglas
1990 D250, NV5600, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07, HX35....IC soon
1991 D250, 16cm housing
Douglas2 is offline
