93 throttle positioning sensor problems - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-26-2011, 08:21 PM Thread Starter
I have installed 2 new TPS's on my 1993 Dodge diesel pickup and they keep going out in about 1/2 hour of use. Then the truck will not go into overdrive. Any ideas what could be wrong?
jcbeyea is offline
post #2 of 4 (permalink) Old 09-26-2011, 10:34 PM
92betsy's Avatar
Ditch the TPS return it for your $200 dollars. Get a cord with 3 wires and a potentiometer from radio shack for 5 dollars and wire it to the wire that plugs into the tps.
Super Cool and CHEAP TPS fix! Dial-in your OD shift point! - Dodge Diesel - Diesel Truck Resource Forums
Installing a Potentiometer in place of the TPS - Dodge Diesel - Diesel Truck Resource Forums
Look through these threads.
Dustin
92' ext cab d350 dually
92betsy is offline
The Following User Says Thank You to 92betsy For This Useful Post:
jcbeyea (09-27-2011)
post #3 of 4 (permalink) Old 09-27-2011, 12:52 PM
Left out in the cold's Avatar
I would be looking for what is making the TPS go out before spending more money.
Left out in the cold is offline
post #4 of 4 (permalink) Old 09-27-2011, 04:23 PM
all the TPS is an extremely expansive potentiometer in a factory package.
i agree with "Left" You need to find out why its burning out. I would be willing to bet the computer is ether over powering it or you have a break in the wire that is causing an over power condition
on Project 92 D350 Cummins 5.9 12 v Turbo Diesel in front of a rebuilt A618 with Manual OD. 4" DiamondEye straight pipe, Factory Tach, Glowshift 3 in 1 (EGT, Boost, Temp)
NWBrew is offline
